Drivetrain Drive Axle Change out
Old 08-16-2016, 11:35 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Originally Posted by backsidedriver
I am about to undertake a right side cv axle replacement on my 2004 Mini Cooper R50. From what i have seen/read it looks straight forward. Question i have is do i have to grease the end that goes into the CVT Automatic Transmission and if so what kind of grease should i use?
Thats a good question. For my manual transmission cars I always slather a little axle grease on the splines. Just a thin film. I suppose the same would apply for CVT. What fluid does CVT use? Gear oil or transmission fluid?
  #52
Old 08-19-2016, 06:07 PM
backsidedriver's Avatar
backsidedriver
backsidedriver is offline
It used transmission fluid. I saw in person not add anything and another person use standard grease. The old axle looks like it has transmission fluid on it but not sure if that from the transmission or added. Since the old one looks like it had trans fluid on it i'll just do that.
  #53
Old 09-09-2016, 04:30 AM
slo_crx1's Avatar
slo_crx1
slo_crx1 is offline
Ripped inner CV boots are a common failure on these cars now that they're 10+ years old. I replaced mine not too long ago, ended up changing just the inner boots (as long as the bearings are still in good shape and there is no extreme wear on the inside of the pots). The biggest challenge is putting the band clamps on after the grease is packed in and the boot is on, and you can actually use a PEX water piping clamp tool to cinch those clamps down perfectly. Much better than mangling them with pliers or putting hose clamps on.
sprp85
08-22-2015 06:16 AM
FLYM1N1
08-16-2015 01:17 PM
xpunisherx
08-10-2015 10:50 PM
ludedude
08-10-2015 07:16 PM
Quick Reply: Drivetrain Drive Axle Change out
