Drivetrain R56 brakes = R53 JCW brakes?
Old 09-27-2007, 04:30 PM
sonichris's Avatar
sonichris
sonichris is offline
ok, here are the pictures anyway...
as you can see from the last two pictures, the stock brake hose will not work, it has a 90deg fitting. the R56 caliper has the fitting on top. other than that, works great!
Last edited by sonichris; 03-17-2016 at 07:13 AM. Reason: updated links to pictures
  #27
Old 12-15-2007, 02:35 PM
Coen_de_K's Avatar
Coen_de_K
Coen_de_K is offline
great info!!!
So I need the R56 cooper S brakes/discs and brakes hoses and then it is a straight bolt-on ? ?
Cheers
Coen
  #28
Old 12-16-2007, 08:57 AM
sonichris's Avatar
sonichris
yep. i'm just waiting for some decent pads to become available for the 2007 mini s. what's taking so long?!
  #29
Old 12-16-2007, 08:58 AM
Coen_de_K's Avatar
Coen_de_K
thanks for the info m8!!! :D
Cheers
Coen
  #30
Old 12-16-2007, 09:04 AM
minimusprime's Avatar
minimusprime
minimusprime is offline
wow this aught to set up some r53 owners with a very cheap, very solid brake upgrade. good work!
  #31
Old 12-16-2007, 09:33 AM
Mini Fireman's Avatar
Mini Fireman
Mini Fireman is offline
Hawk makes pads that fit them now.
  #32
Old 12-16-2007, 09:46 AM
BSUCardinalfan's Avatar
BSUCardinalfan
BSUCardinalfan is offline
FWIW, late '06 R53s had the JCW brakes standard. Mine has 'em.
  #33
Old 12-17-2007, 05:42 AM
sonichris's Avatar
sonichris
i'm holding out for ferodo DS2500's...
  #34
Old 12-17-2007, 01:13 PM
checkers's Avatar
checkers
checkers is offline
you should have went with the JCW 07 rotors also. They are a bolt on also if you have a JCW brake kit. Mines an 05 with the JCW brake kit and they bolted right on. The 07 JCW rotors are drilled & slotted. The new rotors cost about $200.00 for both.
  #35
Old 12-17-2007, 01:14 PM
minimusprime
i disagree. I think the oem aero non drilled rotor is a better choice. Drilled rotor + track temps = cracked rotor.
930 Engineering (10-30-2023)
  #36
Old 12-17-2007, 10:25 PM
sonichris's Avatar
sonichris
i'm planning on tracking this car occasionally, so no drilled rotors for me. i'm sure powerslot will come out with rotors for the R56, which is what i would like to get.
  #37
Old 12-18-2007, 12:02 PM
checkers's Avatar
checkers
checkers is offline
I'll let you know if they crack. I track mine a few time a year. I feel they stop a little quicker. But that's just me.
  #38
Old 12-19-2007, 01:16 AM
fishbulb's Avatar
fishbulb
fishbulb is offline
WOW! Nice bonus for you on that one!
I wonder how that would play into Stock autocross classing?
  #39
Old 12-19-2007, 03:20 AM
pmello's Avatar
pmello
pmello is offline
Slightly OT. Can I assume that the late 2006/07/08 rear pads are the same as 2002/05??? I have an extra set of rear Carbotech #10's that I hope will fit on a new 2008. I have used the Ferodo DS2500's. Like the Carbotech better. Better initial grip and better fade resistance on a track with not much time for cool down between turns.
  #40
Old 12-19-2007, 03:32 AM
TheWrks's Avatar
TheWrks
TheWrks is offline
Coordinator :: Michigan MINI Motor Club
Got mine a while back, painted and they are sitting in the closet awaiting for the S/S lines and warmer weather.
  #41
Old 12-19-2007, 04:29 AM
sonichris's Avatar
sonichris
i'm planning on running these pads on the street so i am willing to sacrifice some performance. i picked the ds2500 because of the high coefficient of friction that stays stable over a large temperature range. what carbotech compound are you comparing the ds2500 to and can you run it on the street?
  #42
Old 12-19-2007, 09:30 AM
BSUCardinalfan
since it came from the factory, it is perfectly legal. goes along the same lines as the LSD and non-LSD cars are in the same class.
  #43
Old 12-19-2007, 11:04 AM
fishbulb's Avatar
fishbulb
fishbulb is offline
I should have finished that thought - I think it was late (or early!)
is backdating allowed? Does that open the door to anyone with a 2006 to add the same brakes? What about other years?
Strictly academic here, I already have a pulley - so it doesn't matter to me. I am just curious what would happen, esp. at a national level event.
  #44
Old 12-20-2007, 02:45 AM
pmello's Avatar
pmello
pmello is offline
Sonichris:
Carbotech 10's front and rear. I ran them through the winter and saw a few 10deg days. Good initial bite even at that temp. They do have some noise (not squeal) at light pressure and slow speeds (less than 5 mph). They wear well both on the street and track. There is no accelerated wear on pads or disks on the street when driven slowly.
  #45
Old 12-20-2007, 11:53 AM
BSUCardinalfan
I'm pretty sure you can't update/backdate in stock. All of the other classes (ST, SP, etc) allow update/backdate.
  #46
Old 12-22-2007, 03:00 PM
omgzilla's Avatar
omgzilla
omgzilla is offline
I've got a set of R56 front brakes for sale guys!
More info here: https://www.northamericanmotoring.co...d.php?t=123685
  #47
Old 12-25-2007, 03:27 PM
auscoops's Avatar
auscoops
auscoops is offline
PM Sent omgzilla, AUS member here
Happy Christmas for those in the States.
Question for everyone else...
Has anyone driven and confirmed that the lug bolt size on the r53 does not need to be changed to suit the larger r56?
I am interested in the upgrade, but want to be sure that i'll work!
Cheers
Roland
  #48
Old 12-25-2007, 03:39 PM
auscoops's Avatar
auscoops
auscoops is offline
Another question...
If i got the r56 calipers... and if i wanted to upgrade the rotors, couldn't i just get gen1 spec JCW rotors? then there wouldn't be any lug size issue? Would that work?
  #49
Old 12-25-2007, 03:56 PM
sonichris's Avatar
sonichris
Cheers
Roland
Another question...
the holes in the R56 rotors are bigger, so the lugs will fit no problem. the pictures above are my R53 with stock lugs and R56 rotors.
  #50
Old 12-25-2007, 10:35 PM
auscoops's Avatar
auscoops
auscoops is offline
So that being said, are there no reliability issues to be had with having a rotor that has bigger holes than the lug? So, this straight swap from r53>r56 rotors/calipers is as simple as swapping it out?
Cheers
Roland
Quick Reply: Drivetrain R56 brakes = R53 JCW brakes?
