R56 Front Brakes Sensor
How many brake wear sensors are needed on the front? I'm replacing pads and rotors on the front.
http://www.ecstuning.com/Mini-2009-C...ors/ES2018160/
+1 one on the front left ( driver side). Just clip it back in location like the old one. I start clipping the old one out while clipping the new one so it follows the same exact location and bends / clips on the ABS and such.
http://www.ecstuning.com/Mini-2009-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Braking/Sensors/ES2018160/
It marked on the brake rotor set screw which I would replace whenever doing brakes as the old ones with corrode and stick. out a little anti-seize on the thread of a new one.
Torx head takes T50 size for install. 1 screws per rotor.
Link to 2009 R56 MINI Cooper Base ( Non S ):
http://www.ecstuning.com/Mini-2009-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Braking/Rotors/
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
JPMontes3
08-23-2015 01:26 AM
