Gas Cap Stuck/Misthreaded/Check Engine Light On
So me and my car are new to this site--been meaning to join forever--it just took this problem I have no idea to fix, to get me to do it.
4 days ago, the Check Engine Light came on. Pulled over, checked everything under the hood--all good. Hmmm.
At the pump today to fill up and my gas cap--no, not the door flap--the black cap that clicks when you tighten it-- will not budge. Not one millimeter. I skin my knuckles. I drive home. Pipe wrench just chews up the plastic outer plastic. I look closer as I bleed and on the bottom of the cap it says and I'm paraphrasing here:
If the cap won't release and the check engine light is on, the cap is mis-threaded.
Okay. Cool. But how do I release it so I can put gas in my car?
You need to force it...
Yes a pipe wrench will work but unless you cover the jaws the hardened steel teeth will really chew up the plastic.
If you have the time and the tools you can make a wooden wrench like the old style wheel cap wrench ...something like these...
Best of luck...
Motor on!
Best of luck...
Motor on!
Hop you can get it off, the older ones clicked a little bit more and where green on the bottom, the newer design ones click once have a blue seal and a black base. Also have a little more writing on them. Good luck you might have to get some channel locks out and get medieval on it alright. Here is what it looks like off.
http://www.ecstuning.com/Search/SiteSearch/16117222391/
Good luck.
Good luck.
07-16-2020 12:54 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
mrjolliff
10-09-2015 05:55 AM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
