WILL THIS FIT R53? Brake conversion
Hello so I’ve been doing my research regarding retrofitting r56 S brakes to r53 Cooper S.
Just trying to do the math here. Used calipers with carriers are around 130 bucks. Plus rebuild kit around 20 bucks. Can’t find them cheaper. Plus new slotted rotors, pads, brake lines and sensors. I found this https://www.carid.com/2007-mini-coop...088797614.html anyone used this for the r53? Or r56? Since it’s for the r56 i shouldnt have any problems fitting them right? just need the carriers. Brake lines and sensors. Thanks for the inputs. |
I've never heard of this make. Best to see where its made first.
I would go with a better known name like Brembo . . . . . |
Brembo or wile oof will be best. But that’s way up there. Itching to save some cash
I did the R56 S brake upgrade on my old r53. I bought rotors, calipers and pads from AutoAnything in a kit by Stop Tech and was very happy with it. I don't think you need to mortgage your house for Brembo or Wilwood to get good stopping power.
Originally Posted by fridayxiii
(Post 4485842)
Or this will work? |
Have you checked out this? https://www.northamericanmotoring.co...rakes-kit.html
(Post 4486433)
Yep :)
(Post 4486444)
Yep :)
And i can reuse the rear if hasn’t tripped yet? |
(Post 4486444)
Yep :)
Yep,
R56 Front brake lines: You just need the fronts, https://www.ecstuning.com/Mini-2007-...Braking/Lines/ R56 Brake sensor front: https://www.ecstuning.com/Mini-2007-...aking/Sensors/ Just shop it like another model, the architecture is the same. :) |
Let me ask a contrary question. Why bother with the brake upgrade? What about the current brakes are inadequate? If you're tracking the car, get race pads. If that's not enough, plumb some cooling in. If you want shorter stopping distances, put on softer tires. 99x out of a hundred, I'd argue, the primary advantage of a brake upgrade is being able to tell your buddies "big brakes".
Originally Posted by RangerGress
(Post 4488499)
So i can’ post that i did it here on NAM 😉
Originally Posted by Serafin
(Post 4488525)
Its because i can. That’s why i love the mini. Always something to do
Actually you need our front conversion lines as they are designed for the R56 to R53 conversion. R56 lines won't fit correctly as they are not made to fit an R53 since the ends are different.
https://www.waymotorworks.com/stainl...rsion-kit.html
(Post 4488499)
Buying a softer more performance tire would just wear out faster for street use. But we do also use them for the performance gain. |
Originally Posted by WayMotorWorks
(Post 4488593)
https://www.waymotorworks.com/stainl...rsion-kit.html Actually this brake upgrade is the same as original JCW upgrade was. If you drive one with these brakes you'll see the car stops much better. Buying a softer more performance tire would just wear out faster for street use. But we do also use them for the performance gain. Brakes aren't that complicated. There's Front/Rear bias, firewall and caliper stiffness that results in a solid pedal feel, and heat resistance. Other variables that aren't occurring to me as I sit here with my beer? Heck, I'd argue that daily driver's are so front biased that if someone really wanted to shorten stopping distances w/o going to sticky tires, they'd delete the bias valve and put the big brake kit in the rear. |
(Post 4488593)
https://www.waymotorworks.com/stainl...rsion-kit.html Actually this brake upgrade is the same as original JCW upgrade was. If you drive one with these brakes you'll see the car stops much better. Buying a softer more performance tire would just wear out faster for street use. But we do also use them for the performance gain. What about the brake sensors? |
(Post 4485842)
It would be a very small house given that you can do a complete front BBK for about $900. Makes looking at the alternatives and multi source shopping questionable. |
(Post 4488718)
Thank You been looking for this.
(Post 4488636)
I certainly accept that you've huge Mini experience, and that's a helova contrast to me. But that doesn't get a person a buy on a phrase as vague as "stops much better". Physics pls.
Brakes aren't that complicated. There's Front/Rear bias, firewall and caliper stiffness that results in a solid pedal feel, and heat resistance. Other variables that aren't occurring to me as I sit here with my beer? Heck, I'd argue that daily driver's are so front biased that if someone really wanted to shorten stopping distances w/o going to sticky tires, they'd delete the bias valve and put the big brake kit in the rear. The R56 calipers are a solid mount unlike the stock R53 that have the rubber bushings if you want that variable. And obviously the pads, rotors, and caliper pistons are all larger than the stock R53. The intern gives you more surface area, pad contact, and clamping force. Not to mention heat dissipation over repetitive use and hard use. Since the R56 S calipers are the same size and pads that the R53 JCW brake kit was there isn't a concern over bias or brake pressure since it is making it the same as the JCW was that used everything else the same on the R53. You can't "delete" the brake bias as it is built into the ABS unit so you can't delete it. And you would never want to make the bias to the rear as locking up the rear would make the car dangerous as it wouldn't be controllable at the point of lock. |
JCW or Brembo conversion
Hi all, I am thinking of doing the R53 to R56 brake conversion but, I see some deals on used and new Gen 1 JCW brakes that are available. My question is; what is the performance gain of JCW Gen. 1 1-piston brake system vs Brembo/JCW 4 piston brakes? Is the performance gain the same as R53 brakes to Gen. 1 JCW brakes or is the cost/braking gain not beneficial to go Brembo.
