2nd gen RFs need special wheels?
I am not sure if this is true, but I heard that the 2nd gen RFs need wheels that have a taller side lip or something like that. In other words, 2nd gen RFs won't work on our wheels and would have to use 1st gen RFs. Is this true? TIA:thumbsup:
Originally Posted by JustJAY
(Post 1532832)
https://www.northamericanmotoring.co...ad.php?t=94225 You can use 2nd gen RF with EH2+ hump on older MINI rims. The newer made MINI rims are slightly different to help support the newer RF tires due to slightly softer sidewalls they are designed with. I figure the newest rims are better able to support the newest design of runflat tires. For example you can use- 195/55R16 Goodyear Excellence Runflats on any MINI with 16x6.5" rims (or other suitable rim). See http://www.mini2.com/forum/wheels-ty...run-flats.html Post #9 New runflats will work safely with older rims. And the newer runflats are quite a bit better than the older runflats. |
