N18 NM module
Engine - Power Adders
  • Engine - Power Adders - N18 NM module - Used - All Years  All Models - Greenfield, WI 53221, United States
Community Builder
    $215
  • Location Greenfield, WI, 53221, USA
Selling my NM module.
I've tested jb+ , RaceChip gts and the nm module and I can HONESTLY say , the NM module definitely added the most power.
the module is like new , no cracks or anything on the wire harness and wires are all still soft.
without the nm module i make 20psi and with the nm module set to high I make 25psi !!!! It also never caused an error code/cel or anything.
the ONLY reason I'm selling it is I'm FINALLY going custom tune. which I've put off for so long because this nm module ACTUALLY is VERY impressive.
Dollar for dollar , your not going to add more get up n go/power to your car than with this for this price..
i believe i still have the box and installation/instructions manual too for it..
( video is my car running the nm module set to high )
i will also throw in very gently used blacked out side scuttles ( not a scratch on them ) along with a boost tap jyst encase you choose to run an ACTUAL boost gauge off of ACTUAL boost/vacuum source not ecu calculated psi/vacuum.
215$ shipped to lower 48x. Paypal ONLY.
Pm or respond to this post..
Start safe N motor on !!
Old May 12, 2026 | 02:35 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Cmon guys , your leaving ALOT of power on the table running a stock tune WITHOUT this nm module.
I promise you , YOU WILL LOVE this upgrade. You don't have to run it at full +4psi either . It has a low amd high setting and the low setting is less aggressive amd has a more liner boost ramp but cmon , at max setting is the FUN SETTING.
Even WITH all my other bolt on amd big turbo I STILL NEVER got a cel or error code with this nm module UNLIKE the jb+ or gts RaceChip would occasionally cause..
I'm telling ya , you'll LOVE this upgrade. And for 200 amd 20min install YOUR NOT GOING TO GET MORE FOR even close to that..
Old May 12, 2026 | 11:50 AM
MiniManAdam
Community Builder
A few freebies added to try and sweeten the deal for ya.
Old May 12, 2026 | 11:51 AM
MiniManAdam
Community Builder
