2007 Mini Cooper S
For Sale2007 Mini R56: "Mk II" Mini Hatch/Hardtop range
Price
$4,500
- Location York, PA, 17402, USA
- Condition Used
- VIN WMWMF735X7TT85248
- Mileage 120,600
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Hatchback
- Exterior Color Red
SOLD OCTOBER 11 2024
For sale is my “chili red” color 2007 Mini Cooper S, with the 1.6L turbo engine and six speed transmission. This has the sports package which includes, xenon headlights, limited slip differential, sport mode, etc. I have the title in hand, which is free and clear.
Car body is in decent shape. There are some typical, very small dings or scratches. The paint is mostly immaculate – has been paint corrected and sealed recently. All of the chrome body lines have been blacked out with vinyl tape, which sometimes does lift at the ends and chrome is exposed underneath. The black rings around the headlights are slightly flaking, as they were painted black.
Interior is in average shape for an 18 year old car. Normal wear and tear, plus one side of the drivers seat has the fabric pulling up a bit. The car audio system is all aftermarket, high quality components, amplified and sounds amazing. Wireless Car Play works flawlessly.
The engine is in great shape. A ton has been replaced for preventative maintenance. All of parts replaced and modifications are listed at the bottom of this posting. I have paperwork for much of this (from a Mini specialist shop) and will provide it with sale. Oil replaced yearly (driven less than 2k miles per year), cabin air filter replaced yearly. Air filter, MAF & MAP sensors cleaned yearly, too. Only filled with 93 octane. Has current PA inspection/emissions that expire in January 2025.
The only item to note is that there is a very, very slow oil leak. I’m talking approximately two drops after driven and sitting overnight (not every time, either). Mechanic could not find the leak in January 2023 when I took it in and most of the parts that could leak were already replaced. I’m thinking it could potentially be old, spilled oil on other parts that leaks when it heats up. I check the oil religiously and rarely have to top it off.
Parts Replaced:
-Front right axle | March 2021
-Serpentine belt | March 2021
-Front brake lines | March 2021
-Brake fluid flush | March 2021
-Transmission fluid flush | March 2021
-AGM battery (battery registered to ECU) | March 2021
-Engine block to chassis ground strap | March 2021
-Pioneer DMH-W4660 NEX Head Unit | April 2021
-Focal Access 165AC Speakers | April 2021
-Focal TWU 1.5 Tweeters | April 2021
-JL W3V3 Subwoofer w/ ported enclosure | April 2021
-Rockford R2-750x5 Amplifier | April 2021
-Ultra Gauge EM Plus | May 2021
-Detroit Tuned Turbo Oil Line Super Kit (https://www.detroittuned.com/detroit...ine-super-kit/) | July 2021
-Turbo feed line, oil return line, oil filter housing, oil cooler seals
-Reseal oil pan | July 2021
-Front crank seal | July 2021
-Enkei RPF1 17” Wheels w/ BFG g-Force Comp-2 A/S Tires 205/45/17 | September 2021
-Invidia Q300 Cat Back Exhaust || July 2021
-H&R Lowering Springs | July 2021
-Rear Wiper Delete | July 2021
-AEM cold air intake | October 2022
-Osram D1S Cool Blue Intense HID Xenon Bulbs | October 2022
-Nokya Yellow Fog lights | October 2022
-LED interior bulbs | October 2022
-LED front signals & parking lights | October 2022
-Coolant overflow tank | January 2023
-Vacuum pump | January 2023
-FRM repair & reprogram | September 2024
-Powerflex lower motor mount insert | September 2024
-Diverter valve replacement | September 2024
Prior owner claimed to have replaced the front left axle, timing chain/water pump, and valve cover gasket but I did not receive paperwork to verify this.
Very good car, it’s my daily driver and has not given me problems despite being almost 18 years old. I am selling because I’d like something a bit larger with four doors.
Price is OBO. Car is sold as is, no implied warranty.
