1st Gen Timing Tool Kit from WMW
Miscellaneous
  • Miscellaneous - 1st Gen Timing Tool Kit from WMW - Used - 2002 to 2008 Mini R53: "Mk I" Mini Cooper S - Vashon, WA 98070, United States
    Expired
    Expired
    $80
  • Location Vashon, WA, 98070, USA
  • Compatibility
Make Model Year
Mini R53: "Mk I" Mini Cooper S 2002 - 2008
Complete timing tool kit from Way Motor Works.
Timing Tool Kit for 2002-2006 R50 R53 MINI Cooper and Cooper S, and R52 MINI Convertible. If you are going to replace the cylinder head, or timing chain on your MINI this is a must have tool kit. This kit has the lock that holds the camshaft to loosen the camshaft sprocket bolt and tighten it. Also has the mount and bolts to hold the engine while the passenger side engine mount is off the card. Then the kit also has the tool to reinstall the crankshaft pulley if you have to remove it to check the timing or replace the chain.
Kit includes:
Camshaft lock tool
Engine mount holder
bolts for mount
Crankshaft pulley install tool
carrying case
Sells new for $149.  Yours for $80+shipping.
Old Sep 30, 2024 | 10:10 AM
Husky44's Avatar
Husky44
Deleted post
Old Jan 12, 2025 | 02:37 PM
Husky44's Avatar
Husky44
Bump
Still available.
Old Jun 29, 2025 | 07:18 PM
Husky44's Avatar
Husky44
Bump
Still available.
