2005 Mini Cooper S, R53
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - 2005 Mini Cooper S, R53 - Used - VIN WMWRE33405TD97935 - 113,445 Miles - Manual - Coupe - Gray - Phila Suburbs, PA 19087, United States
    $7,000
  • Location Phila Suburbs, PA, 19087, USA
  • VIN WMWRE33405TD97935
  • Mileage 113,445
  • Transmission Manual
  • Vehicle Type Coupe
  • Exterior Color Gray
I rescued this car with 111,000 miles and a blown head gasket but it still ran fine. It was somebody's baby, always garage kept, never driven in winter. Dealer service records indicate all recalls were addressed, including the steering pump and seat occupancy sensors. I had the engine and supercharger rebuilt to factory specs and took the opportunity to replace all the parts listed below while the engine was out. All replacement parts are OEM or equivalent. The only aftermarket addition is the oil catch can, which goes a long way towards keeping the intake manifold MAP sensor clean. I did it right. This is a fresh car, runs and drives like new, ready for every-day duty or toy-car modifying. There are some parking lot dings but otherwise it is clean as can be.
Six-speed, limited slip diff, sunroof, gauge package, Harmon Kardon, heated seats, climate control, cloth interior
Freshly rebuilt engine and Stiegmeier supercharger. New radiator and foam seal kit, thermostat and housing, all hoses, oil cooler, oil filter drain-back valve, engine mounts, rear brakes/rotors and calipers, front brakes/rotors, new front axles, complete ignition system, both MAP sensors, fuel filter, clutch assembly and slave cylinder.
New headliner, garage-kept, no rust, excellent interior, tires almost new.
Old Jun 29, 2024 | 04:33 AM
jgordon9's Avatar
jgordon9
test
