Supercharger Pulley Puller Tool for Stock R52 R53 MINI Cooper S
Miscellaneous
  • Miscellaneous - Supercharger Pulley Puller Tool for Stock R52 R53 MINI Cooper S - Used - 2002 to 2008 Mini Cooper - Austin, TX 78738, United States
Alliance Member
    $45
    • OBO • Trade
  • Location Austin, TX, 78738, USA
  • Compatibility
Make Model Year
Mini Cooper 2002 - 2008
Supercharger Pulley Puller Removal Tool for Stock R52 R53 MINI Cooper S.
Comes as seen in picture with black clam style puller, bolt, and anti seize for bolt.
This supercharger pulley removal tool will press the stock supercharger pulley off of the MINI Cooper M45 stock supercharger.  The puller allows you to remove the pulley without removing the belt tensioner.  It hooks over the top of the stock supercharger pulley and then as you tighten down the bolt on the puller it will press against the supercharger shaft and pull the pulley straight off.
This ONLY works on the stock 2002-2006 R53 MINI Cooper S or 2005-2008 R52 Convertible S with the stock supercharger pulley.
This will NOT work on the John Cooper Works pulley as it is smaller so this puller will be too big.
If you are going to upgrade your supercharger pulley this is a must have to do the job not only right, but quickly as it will reduce the parts that you have to remove for the job.  Also it will prevent you from damaging the supercharger as you won't have to pry on the shaft or anything.
FREE shipping to CONUS ! Will trade for JCW pulley puller!!
