Jcw turbo
Engine - Power Adders
  • Engine - Power Adders - Jcw turbo - Used - All Years  All Models - Oakcreek, WI 53154, United States
Community Builder
    $380
    • OBO • Trade
  • Location Oakcreek, WI, 53154, USA
Car has 117k and was 100% until I got it. I found the turbo wastegate nut wasn't on so I don't know forsure if the wastegate is good or not still but I will sell it asis as if it is bad. It has 0 shaft play , makes boost just fine and burns no oil. A replacement wastegate is 40$ only worse case. And the turbo is off so why not replace it ?
when i removed the downpipe the tops stud boogered the last thread BUT I PERFECTLY tapped it and I chose to use a bolt for the top because it made install much easier as a pose to 3x studs.
380$+ SHIPPED to lower 48, PayPal is preferred.
Pm or respond to this post.
stay safe n motor on !!!!!
Old Feb 17, 2024 | 06:05 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
To answer a few questions I've gotten....
NO ! this turbo absolutely DOES NOT burn or smoke one bit , it has absolutely 0 shaft play and in all honesty the wastegate might be fine , I just didn't wanna bother resetting it because I bought it and the wastegate rod nut had backed off and at that point I already ordered a upgraded turbo.. with my tune the turbo was making 25psi but would dip down to 15psi and climb back to 25psi because of the wastegate nut missing.
I ALSO made sure the top thread were PERFECTPERFECTLY fixed with a tap because these turbos like to have the studs back out and they will damage threads. I thread locked the bottom 2x studs in and choose to use a bolt instead of a stud for the top ONLY because it made install of my downpipe easier. You can insert a stud again if you choose.
I will ALSO lower the price to 380$ SHIPPED to lower 48.
or id LOOOOOVE to trade for an aem or ddm works intake with an underhood scoop so i can finish my intake project..
Act fast ! Because if not sold soon I'm giving it to someone to install my new turbo fir me ( save me some work but I'd definitely rather trade it or pocket some $$)..
boost away my mini brother's !!!!!
