Advanced Clutch Technology BM2-HDG6 Clutch Kit
Miscellaneous
  • Miscellaneous - Advanced Clutch Technology BM2-HDG6 Clutch Kit - New - All Years  All Models - Austin, TX 78738, United States
Alliance Member
    $500
    • OBO
  • Location Austin, TX, 78738, USA
  • Condition New
BM2-HDG6 kit features ACT's most popular Heavy Duty pressure plate. ACT Heavy Duty pressure plates use exclusive diaphragm design to increase clamp load, reduce deflection and maximize clutch life. All diaphragms endure a four-stage, heat-treating process for unparalleled performance. ACT pressure plates have precision cover stampings to provide rigidity and consistency. ACT's 6-pad, spring-centered race disc features a spring-center to properly damp torsional vibrations and resist failure under harsh conditions. ACT spring retainers utilize wraparound spring windows and thicker retainer stampings to provide spring support, reduce stress concentrations, and increase strength and reliability. With the 6-pad, spring-centered race disc, engagement is harsher, but shifting is faster. The 6-pad, spring-centered disc is recommended for larger clutch sizes to absorb more heat.
Description  Light to moderate pedal effort, aggressive engagement, OE to mild gear rattle   Moderate friction life, extended by ACT's exclusive diaphragm design   Carefully engineered, precisely assembled, accurately balanced, uses select ceramic friction materials for high heat tolerance and maximum performance   Recommended for high horsepower street or race use   100% clamp load tested and dynamically computer balanced for smooth high RPM reliability.
Fits: 2002-2008 1.6 L4 Gas Fl 1600cc / Supercharged
Must use ACT flywheel with spring hub discs (flywheel not included in this listing).
FREE shipping within CONUS
RETAILS for over $750
