Modified 2007 MINI Cooper S/JCW 6-Speed
For Sale2007 Mini R56: "Mk II" Mini Hatch/Hardtop range
Price
$10,950• OBO
- Location Bethel, CT, 06801, USA
- Condition Used
- VIN WMWMF73587TT82199
- Mileage 76,000
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Coupe
- Exterior Color Other
British Racing Green Metallic/White Roof, Mirrors and Wheels
Original Owner • No Accidents • No Issues • No Leaks • No Codes
The Big Four Performance Upgrades
JCW Tune + Manic Stage One Tune w/Switch
In 2007 there was no factory R56 JCW. In October 2007, MINI introduced a JCW upgrade tune and I had it dealer installed. Subsequent to that, the Stage 1 Manic tune was installed by Way Motor Works in Atlanta. Both tunes are currently on the ECU. The Manic switch allows you to run the JCW tune or the Manic tune.*
Akrapovic Turbo-Back Exhaust
Includes a high-flow downpipe and the great-sounding Evolution exhaust with carbon fiber tips. The high-flow downpipe is required to run the Manic tune. Passed CT emissions multiple times with the high-flow downpipe and Manic tune.*
*NOTE: The OEM downpipe has been reinstalled for the sale and the tune switched back to JCW. Take $500 off the price if you do not want the Akrapovic downpipe and Manic switch.
Wilwood Big Brake Kit (Front) and Oversize Rotors (Rear)
On the front are Wilwood DynaPro 6A forged calipers over Wilwood 12” slotted rotors. The rear uses the OEM calipers attached to an extension bracket to allow for oversize rotors. To revert to less-expensive OEM rear rotors, just remove the bracket.
Ohlins Road & Track Adjustable Coilovers
Kit number BMS M120. This setup was engineered exclusively for the MINI R56 and is a game changer on a car that already boasts legendary go-kart handling. Includes Vorshlag Camber Plates. 24 adjustment settings.
Additional Upgrades
Engine/Transmission·
- SPEC Stage 2 Clutch and Dual Mass Flywheel
- Helix Stepped Core Performance Intercooler
- NM Engineering Hi-Flow Induction Kit/Cold Air Intake
- Much more
- NM Engineering 17”x7.5” RSe05 White Wheels (16 lbs) with NEW (less than 2k miles) Michelin Pilot AS3+ ultra high performance all-season tires
- Rear Sway Bar and underside Chassis Brace
- PowerFlex Poly Bushings
- Much more
- John Cooper Works Body Kit
- MINI GP Rear Diffuser
- M7 Mesh Front Grilles
- Much more
- Marshall Oil Temp and Boost Gauges
- JCW Steering Wheel
- Much more
Included With Sale — Bentley Repair Manual and dozens of miscellaneous extra parts, bits and pieces worth hundreds of dollars.
For more details and 300dpi photos, PM me your email address. Serious inquiries only. Thank you for your interest.
