IP High Performance Ignition Coils
Engine - Electrical
  • Engine - Electrical - IP High Performance Ignition Coils - Used - 2007 to 2012 Mini R56: "Mk II" Mini Hatch/Hardtop range - San Diego, CA 92130, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    $340
  • Location San Diego, CA, 92130, USA
  • Compatibility
Make Model Year
Mini R56: "Mk II" Mini Hatch/Hardtop range 2007 - 2012
These were removed from a wrecked 2010 R56 N14 Mini Cooper S. From what I can tell, these should also work for a N18 (and other 4 cylinder BMW's) but please do your own reattach for additional compatibility. One coil is missing the clip mating surface on one side, but it doesn't affect retentions of the electrical connections (see picture).
The IP Coils are the ignition coil with a high power amplifier built in to it. The IP Coils produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
Engineered in Japan, Handmade in USA. Ignition Projects IP Coils are designed in Japan and handmade at our facility located in Tustin, California. To ensure the highest level of quality, every product is tested with industrial grade oscilloscope before shipping.
