2005 Cooper S R53 Hyper Blue Metallic with 99K Miles Automatic w/paddles, Aero Kit
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - 2005 Cooper S R53 Hyper Blue Metallic with 99K Miles Automatic w/paddles, Aero Kit - Used - VIN WMWRE33535TG98854 - 98,700 Miles - 4 cyl - 2WD - Automatic - Hatchback - Blue - Clifton, VA 20124, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $4,900
  • Location Clifton, VA, 20124, USA
  • VIN WMWRE33535TG98854
  • Mileage 98,700
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Hatchback
  • Exterior Color Blue
I am the third owner and bought it from a fellow member not long ago in October and got it shipped from TX. I never thought or had an intention to sell it that quickly but due to recently found issues, I need to let it go.
Issues:
  • Once the car warms up and driven for about 8-9 miles, the gear shifting gets harsh.
  • Oil filter Housing leaking
  • Oil Pan Leaking
I would have taken care of the oil leaks but the transmission is my breaking point. GT Peace in Chantilly has given me an estimate of replacing the whole transmission with a used one with 86K miles, but it’s pricey. I asked if replacing the valve body will fix the issue but it may or may not fix the issue. Hence replacing the transmission was suggested.
The car had a minor accident damaging its hatch, which was professionally repaired. There is complete paperwork capturing the repair work.
On the other hand, there are so many good things going on with this car. Anyone with time and resources can make it 100%.
The car has great options and pluses:
 ·       Premium, Sports, and Cold Weather Package
·       Aero Body Kit
·       JCW Exhaust
·       New Headliner
·       Factory Navigation
·       Rearview Mirror with Homelink Garage Door Opener
·       Harman Kardon Sound
·       Bluetooth
·       Heated Leather Seats
·       All Electronics in working condition
·       Windows and Locks are functional
·       Paddle Shifters
·       Maintenance Record since 2011
·       2 Keys
·      No Check Engine Light or Fault Codes
Maintenance History:
  • Spark Plugs    @98600
  • Aluminum Coolant Expansion Tank - Black    @98600
  • Brake Fluid Flushed and Replaced    @98600
  • Headliner Repair    @98600
  • Lower Motor Mount    @98600
  • Ball Joint    @98600
  • Hood and Hatch Struts    @98600
  • Rear Strut Mounts    @97943
  • Passenger Side Wheel Bearing    @97943
  • Oil Change    @97580
  • Oil Change    @94281
  • Transmission Service    @90429
  • Throttle Housing Gasket  @Approx. 90400
  • Intake Manifold Gasket  @Approx. 90400
  • Intake Duct Boot  @Approx. 90400
  • Intake Boot  @Approx. 90400
  • Hose    @Approx. 90400
  • Crank Pulley    @90338
  • Thermostat and Expansion Tank Hose    @90338
  • Oil Change    @90338
  • Intake Inlet Pipe    @Approx. 88000
  • Tires    @86723
  • 4 Wheel Alignment    @86723
  • Oil Change    @86723
  • Oil Change    @81699
  • Oil Change    @78952
  • Valve Cover Gasket    @78952
  • Right Front Strut Mount    @78952
  • Rear Sway Bar Bushing    @78952
  • 4 Wheel Alignment    @78952
  • Oil Change    @75015
  • Transmission Harness    @75015
  • Lower Control Arm Bushings    @75015
  • Air Intake Tube    @75015
  • Oil Pan and Oil Pan Gasket    @75015
  • Rear Hatch Repaired due to collision     @71360
  • Right Side Engine Mount    @68634
  • Power Steering Lines Replaced    @68634
  • Crank Sensor O-Ring    @68634
  • Oil Change    @68002
  • Battery Replaced    @64563
  • OC-3 mat replace (sensor mat)    @64563
  • Oil Change    @60502
  • Crank Pulley    @55795
  • Water Pump    @55795
  • Drive Belt    @55795
  • L/F Wheel Bearing    @53712
  • 4 Wheel Alignment    @53712
  • Oil Change    @49172
  • LF Speed Sensor    @48171
  • Rotor and Brake Pads    (Unable to Confirm Mileage)
  • Power Steering Fan Replaced    @35359
  • windshield Washer Pump    (Unable to Confirm Mileage)
Listing by the previous owner can be found below:
https://www.northamericanmotoring.co.../market/366259
Old Jan 30, 2024 | 12:20 PM
stubornn's Avatar
stubornn
Bump
Taking offers.
Old Dec 26, 2024 | 07:04 PM
David Moore's Avatar
David Moore
Originally Posted by stubornn
Bump
Taking offers.
Did you end up selling this?
Old Dec 26, 2024 | 07:15 PM
stubornn's Avatar
stubornn
No, I still have it.
