2005 Mini Cooper S 6 Speed Manual, 124k miles
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - 2005 Mini Cooper S 6 Speed Manual, 124k miles - Used - VIN WMWRE33415TD92856 - 124,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Gray - Littleton, CO 80125, United States
    $6,500
  • Location Littleton, CO, 80125, USA
  • VIN WMWRE33415TD92856
  • Mileage 124,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Gray
2005 Mini Cooper S
BRAND New, within 300 Miles, receipts available
Bilstein b4 shocks all around
JCW R56 Front Brake upgrade
New Calipers, rotors, pads, stainless lines, clips
Rear calipers, rotors, pads, stainless lines, clips, guide pins
Rear wheel hubs
Brake fluid reservoir
Brake reservoir vacuum lines and reservoir grommets
Brake booster check valve
Fuel filter
Fuel pump
Fuel pressure regulator
Fuel pressure regulator vacuum line
Fuel cap
Fuel Tank Breather Hose (Vacuum Hose)
Fuel injector o-rings
Fuel Tank Breather Valve
Fuel Tank Breather Valve Hose
Shift cables
Shifter level box assembly
Cravenspeed shifter
Supercharger/drive belt tensioner
Idler pulley
Cabin filter
Air filter
Oil filter + change
Transmission fluid change
Spark plugs
OEM BMW Ignition Coil
Wires
Power Steering reservoir and lines
Power Steering hose o rings
Power Steering fluid flush
Coolant expansion tank
Full front and rear suspension drop and refresh, including
Subframe Painting
Lower and Upper Ball Joints
Front and Rear Swaybar links
Steering Rack Boots
Tie Rods
Powerflex Road poly bushings front and rear
WMW (Hotchkiss) 25mm Rear swaybar
Hotchkiss upper and lower rear control arms (adjustable)
Subframe bolts front and rear
Crankcase vent hoses
Timing chain tensioner
Cravenspeed flexi dipstick and o-rings
Crankshaft Position sensor
Camshaft Position sensor
Knock sensor
Pre and Post cat o2 sensors
MAP Sensor
TMAP Sensor
Milltek resonated cat back exhaust
OEM exhaust rubber hangers and mounting hardware
OEM Mini Valve cover (with gasket and sealed bolts)
Oil Filler Cap
Upper and Lower Radiator Hoses
Radiator
Water Pump and o-rings
Thermostat and o-ring
Supercharger service (oil and gaskets)
Alta 17% pulley
Throttle Housing Gasket
License plate lenses and light bulbs
OEM Intercooler boots
Yokohama All Season Tires
Supercharger inlet pipe vacuum hoses
Supercharger inlet pipe vacuum hose clips
harmonic balancer
USED, but installed within 300 Miles, receipts available
OEM Airbox
Modified to internal cone filter
Cold air fed from cowl
Extra hot air entry points plastic welded closed
GRS “Motorsport” Intercooler and cowl
LED Interior Overhead Light
Driver and passenger sun visors
Old Oct 15, 2023 | 07:50 PM
EMIgaul's Avatar
EMIgaul
Reduced
Old Oct 25, 2023 | 02:28 PM
EMIgaul's Avatar
EMIgaul
Reduced
Old Dec 8, 2023 | 08:00 PM
EMIgaul's Avatar
EMIgaul
https://docs.google.com/document/d/1...usp=drive_link
See link for LONG list of preventative maintenance and upgrades
