AeroForce Gauges and Cravenspeed Flexpod Mounting Kit - $275
Accessories
  • Accessories - AeroForce Gauges and Cravenspeed Flexpod Mounting Kit - $275 - Used - 2014 to 2024 Mini F56: Mini Hatch/Hardtop - Maineville, OH 45039, United States
    $275
  • Location Maineville, OH, 45039, USA
  • Compatibility
Make Model Year
Mini F56: Mini Hatch/Hardtop 2014 - 2024
I bought these gauges on this site but once I received them I decided to go a different route. I did not install them, just checked to make sure they were working correctly. Retail on the gauges is $439 and the Flexpod is $120 and I'm selling them together for $275 including shipping. Links to the websites are below.
https://aeroforcetech.com/products/i...37434732183706
https://www.cravenspeed.com/the-flex...-mounting-kit/
Here is a partial list of available parameters:
1. INTAKE AIR TEMP
2. AMBIENT AIR TEMP
3. COOLANT TEMP
4. INTAKE VALVE TIMING
5. RPM
6. MAP – Manifold air pressure in kPA
7. BOOST – reads inHg in vacuum, psi in boost
8. MAF SENSOR LB/MIN
9. THROTTLE %
10. CAT CON TEMP B1
11. CAT CON TEMP B2
12. MILES PER HOUR
13. IGNITION ADVANCE
14. SHORT TERM FUEL TRIM bank 1
15. SHORT TERM FUEL TRIM bank 2
16. LONG TERM FUEL TRIM bank 1
17. LONG TERM FUEL TRIM bank 2
18. COMMANDED AIR/FUEL RATIO
19. BATTERY VOLTAGE
20. ENGINE LOAD
21. MILES PER GALLON
22. CALCULATED HORSEPOWER
23. ENGINE RUN TIME
24. COMMANDED EQUIVALENCY RATIO*
25. COMMANDED AIR/FUEL RATIO*
26. B1S1 EQ RAT – Bank 1 sensor 1 equivalency ratio*
27. B2S1 EQ RAT – Bank 2 sensor 1 equivalency ratio*
28. B1S1 A/F RAT – Bank 1 sensor 1 air/fuel ratio*
29. B2S1 A/F RAT – Bank 2 sensor 1 air/fuel ratio*
30. ANALOG 1 – analog input #1
31. ANALOG 2 – analog input #2
Old Aug 20, 2023 | 09:02 AM
Yoshimura 1's Avatar
Yoshimura 1
What color do they light up.....do they match the mini lighting
Old Aug 20, 2023 | 09:55 AM
greenchili2017's Avatar
greenchili2017
You can see the color of the display in the pictures. AeroForce says that they're reversible, so either light letters on dark background or dark letters on a light background
Old Aug 20, 2023 | 05:17 PM
gauss66's Avatar
gauss66
Nice ! I am considering - but I won't oil pressure and believe these will only give that with the N18 ( N14s don't have the E input ). Let me know if I am wrong
Old Aug 20, 2023 | 05:37 PM
greenchili2017
The gauges can accept an external analog signal, so you would have to have a separate oil pressure sender that the gauge could use.
Old Aug 20, 2023 | 06:33 PM
CHiCO43's Avatar
CHiCO43
DMed
