Enlarged throttlebody package , barely used !!!!!
Engine - Intake/Fuel
  • Engine - Intake/Fuel - Enlarged throttlebody package , barely used !!!!! - Used - 0  All Models - Oakcreek, WI 53154, United States
Community Builder
    $250
  • Location Oakcreek, WI, 53154, USA
This is a tried and proven AWESOME upgrade I'd discovered for our cars a few years back and it has become one of the goto mods , aftermarket companies are actually starting to copy me and list them as an r53 enlarged throttlebody for much more $$$. You get a massive amount of more flow AND I personally gained 2psi more max( i made 17psi through my grs motorsport ic but i made 19psi through the stock ic ). Some gain more some gain less. All depends on your setup.
I'm in need of some money at the moment so I went back to stock in the meantime to try and clear a few bucks for a replacement hood.
Everything was used 5x months and maybe 2000miles IF that.
I'm including a bmw 65mm throttlebody TAPPED so you can run stock vacuum routing , CUSTOM made FULL 3in intake that clears everything and fits the tbody perfectly (i have a manufacturer special make these specifically to fit this throttlebody) , also an electronic throttle controller already customized to plug RITE IN and it allows you to fine tune the throttle input because it WILL be different with a larger tbody ( less input give you more air n speed so it can become touchy without the controller) and I'm including a bracket that fits the throttlebody perfectly too so your boost tube will continue to stay in place firmly.
250$ + shipping FOR EVERYTHING.  pm or respond to this post.
paypal is preferred.
stay safe N motor on !!!!
Old Jul 30, 2023 | 09:08 PM
Keysersozeh's Avatar
Keysersozeh
Still available?
Sending PM.
