port N polished r53 intake Manifold
Engine - Intake/Fuel
  • Engine - Intake/Fuel - port N polished r53 intake Manifold - Used - 0  All Models - Oakcreek, WI 53154, United States
Community Builder
    $275
    • Trade
  • Location Oakcreek, WI, 53154, USA
I've made a d sold atleast a dozen of these ported intake Manifolds now and this one I have put the most time and effort into as it was on my personal car. I've spent numerous hours perfect this one. The ONLY reason it's getting removed is I found and bought another nla sneedspeed enlarged intake Manifold and I will finish porting and polishing that and use it instead due to its welded on panel for extra volume ,like on my other mini.
On the ported stock manifold I enlarged all 4x ports all the way down and I also enlarged the inlet opening and down in. I then sand blasted the inside and hand sanded it with 1000grit to further smoothen and polish the inside. I also cleaned the outside so it actually does shine once again and looks very presentable under the hood , not new but far better thsn most crusty ,oxidizing ones you see.. it ALSO provides much much better flow , I correct the air paths to stop cylinder #1 from getting less air and hsving fueling issue with that cylinder ( known issue with stock intakeManifold, you can find info on the web all about it ). My combo with this Manifold is a 19% pulley ( ported sc ) , port n polished ic horn and hat , 380cc , gp tune ,larger 65mm tbody , larger alta ic ( though the grs is pictured with it) , full catless exhaust and my car makes 19psi on stock ic and runs very good iats. Runs much better iat but abit less boost with my grs ic ( about 17psi) and maintains a 12.5afr while under boost.. so this WILL not lean out your car. It will ONLY HELP all around.
i will get more pics as soon as its removed BUT if purchased i will remove IT AS SOON AS the payment is in and ship it asap. If your know or are familiar with me you know I do good business on here with never 1x complaint.
275$ shipped to lower 48 , international shipping available but you must cover shipping. Pm or respond to this post.
i will trade towards and add cash for a water cooled intercooler setup or a direct flow intercooler.
stay safe n MOD on !!!!!!
Old Jul 7, 2023 | 06:40 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I have multiple things for sale so I offer package deals and IF you buy this ported intake ,head or my ic I have forsale I will throw in your choice of 2x things from the picture.. most things are NEW and the foglights DO fit our S bumpers foglight holes perfect.
