H&R Street Performance Coilover Kit (R53)
Steering/Suspension
  • Steering/Suspension - H&R Street Performance Coilover Kit (R53) - Used - 2002 to 2006 Mini R53: "Mk I" Mini Cooper S - Queens, NY 11427, United States
    $750
    • OBO
  • Location Queens, NY, 11427, USA
  • Compatibility
Make Model Year
Mini R53: "Mk I" Mini Cooper S 2002 - 2006
Taken off my 2006 MINI Cooper S (R53). Upgraded to a track setup. Less than 10k miles on these. Good condition.
The fronts include strut mounts, which don't come with the kit. For the rears, you just need to reuse your top strut mounts from your stock setup.
One of the front dust boots has a slight crack near the bottom, but you can probably just cut that out section off clean with a blade and it should still cover that area once the spring is compressed.
When I installed these, I sprayed the threaded shock bodies with Permatex 81464 anti-seize so just needs a quick wire brushing and the locking collars should spin smoothly — this is a maintenance technique I've used in the past and it's a great way to preserve adjustability.
Comes with the adjustment wrenches.
I paid nearly $2000 for these from ECS, so hoping to recoup some of that cost.
Will ship in a double box, use foam and bubble wrap. Buyer pays shipping.
Old Jun 9, 2023 | 05:56 AM
Mini invictus's Avatar
Mini invictus
Are the strut mounts stock replacements or are they adjustable or provide a change in camber?
Old Jun 12, 2023 | 07:21 AM
COOPT UP's Avatar
COOPT UP
Nope — this coilover kit uses the stock strut mounts.
Old Jun 12, 2023 | 07:22 AM
COOPT UP's Avatar
COOPT UP
