Part me out before I decide to rebuild
2012 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2012 Mini R56: "Mk II" Mini Hatch/Hardtop range - Part me out before I decide to rebuild - Salem, OR 97303, United States
Hopping to get some my money back on parts I’ve thrown on this.
new parts:
- cylinder head: pressure tested, lapped valves assembled at a machine shop. 200 psi on all cylinders except for 205 at #3. Still great
- sneed4speed performance rods w/ arp bolts
- Mahle updated version thermostat
- Metal impeller water pump Mfg #11517648827
- oem diverted valve Mfg #11658636606
- valve cover Mfg #11127646552
- used HPFP from a 2012 r56 with no fuel issues. Car was at 90k
- fuel rail, injectors, hardline, sensor from donor car all working condition.
- newly rebuilt HPFP
-new fuel pressure sensor
- will sell my current fuel system, rail, sensor, hard lines
- brand new injectors
- one front wheel hub. In box
- extra valve cover. In box
- piston ring compressor
- blind caps for block. In box
- brand new spark plugs
-1 delphi oem coil
- 4 aftermarket coils. Working condition.
- front sway bar upgrades ALTA
- rear sway bar upgrade, WHITELINE
- timing guides, chain, tensioners whatever you want
- hvac filter
- vacuum lines
- crank sensor
All above parts are brand new on the car with only 10 miles after rebuild. Rebuild failed because I did not deck my block and now my head gasket has failed and seeing combustion gases in coolant. Would rather be done with the car rather than redo the block. Except for fuel system parts from donor mini with 90k and no fuel issues. That car overheated.
plus used parts that came with car. Lots of trim, Harmon Kardon package, interior, leather seats with seat warmers. Only 1 scratch on them Xenon headlights. Mini r98 wheels. Outside lip clear coat has peeled planned to refurbish. Full set. Black mini conical spoke alloys with some curb rash.
Ask for pictures of anything and I will provide! negotiate with me
Picture Title Part Category Price Part Description
Everything Accessories $999 Everything
Old May 26, 2023 | 05:26 PM
Yoshimura 1's Avatar
Yoshimura 1
Are you selling the vehicle or parting out......
