2011 Clubman S 6 speed.
2011 Mini R55: "Mk II" Mini Clubman
  • 2011 Mini R55: "Mk II" Mini Clubman - 2011 Clubman S 6 speed. - Used - VIN WMWZG3C52BTY30540 - 138,300 Miles - 4 cyl - 2WD - Manual - Wagon - Brown - Maricopa, AZ 85139, United States
    $7,950
  • Location Maricopa, AZ, 85139, USA
  • VIN WMWZG3C52BTY30540
  • Mileage 138,300
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Wagon
  • Exterior Color Brown
2011 Mini Cooper Clubman S with 6 speed manual transmission.
138K miles.
Slicktop.
Rain sensor.
Comfort access.
OEM Satellite radio with USB/AUX and handsfree bluetooth.
 Upgrades:
 25w OEM Xenon headlights.
Black headlight trim and door handles.
Black grill and trim.
JCW GP2 Shifter handle with boot.
JCW steering wheel with red stitching.
JCW GP2 belly tray.
CTS Intercooler.
Intercooler muffler and noise maker delete.
Prototype r-type stage 1 tune.
Rear foglight switch installed and coded.
Wavetrack limited slip differential.
19mm rear sway bar.
Maintenance done under my ownership in last 3 years:
 Thermostat, water pump, pulley, belt and belt tensioner and water pipe.
Engine and transmission mounts.
Clutch with all hardware, rear main seal and flywheel.
Oil filter housing gasket.
Turbo oil lines.
OEM valve cover.
Spark plugs and coils.
HPFP and 4 injectors.
MAF sensor.
Both vanos solenoids.
Timing chain guides.
Fuel filter.
Carbon build up removed.
Brake pads and rotors on 4 corners.
Bilstein B6 shocks and struts.
Windshield cowl cover.
Lower O2 sensor.
 Car drives perfect, pulls very strong and everything works as it should. No leaks, no issues.
Does have dings and some minor scratches there and there, but looks great for its age.
$7950.00
File Type: docx
Old Mar 11, 2023 | 08:06 PM
GrneEyeDog's Avatar
GrneEyeDog
bump, lowered price.
