Harrop TVS900 Supercharger for R53
Engine - Intake/Fuel
  • Engine - Intake/Fuel - Harrop TVS900 Supercharger for R53 - Used - 2002 to 2006 Mini R53: "Mk I" Mini Cooper S - Mountain View, CA 94043, United States
    $2,400
    • OBO
  • Location Mountain View, CA, 94043, USA
  • Compatibility
Make Model Year
Mini R53: "Mk I" Mini Cooper S 2002 - 2006
Harrop TVS900 Kit for 02-06 Mini Cooper S R53, w/ RMW Tensioner and 60mm pulley
This kit was purchased from Jan at RMW / Revolution Mini and has <10k miles on it.
Total value of the kit is $3,915 when it was new.
It includes his RMW billet tensioner arm ($315 new) which relocates the tensioner pulley to the proper location to mitigate belt slip.
This supercharger has a 60mm pulley ($100) installed.
This kit includes an electric water pump, relay, bracket, and harness.
It is missing one water hose, which can be easily replaced with many silicone or auto parts store hose. Four generic hose clamps will also be needed to finish the installation.
All other parts that are shown in the photos are included, and the factory installation manual is included.
The TVS900 Supercharger Kit utilizes the latest Eaton TVS supercharger technology and provides superior performance when compared to the smaller, 5th generation M45 supercharger factory fitted to the R53 Mini. A significant benefit of TVS technology is the transition to four lobe rotors providing a 160 degree helix, as well as revised inlet and outlet port geometry to achieve greater thermal and volumetric efficiency. Being a larger displacement than the M45 unit, the TVS900 also provides higher performance potential for modified engine packages.
Through extensive packaging analysis, the Harrop TVS900 Supercharger is of OE appearance and mounts in the factory M45 supercharger position using the FACTORY 6PK belt path and tensioner. Along with the Harrop manufactured Supercharger housing, the kit comes complete with a cast aluminum throttle body adapter, billet outlet adapter and heater hose adapter, replacement electric water pump and all ancillary items to suit stock and aftermarket top mount intercoolers, ensuring this is a complete bolt-on kit.
Key Features:
Eaton / Harrop TVS900
Featuring the latest Eaton TVS Technology
Direct replacement for factory fitted Eaton M45 Supercharger Unit
Designed and Manufactured by Harrop
OE Appearance and engine integration
Old Nov 1, 2022 | 05:58 AM
MINIRescueR53's Avatar
MINIRescueR53
Tvs900
I wish I was in the position to buy this. You don't see these very often. Glws
