Dinan sport performance tuner - 2014-2022 mini
Engine - Power Adders
  • Engine - Power Adders - Dinan sport performance tuner - 2014-2022 mini - Used - 2014 to 2022 Mini All Models - Greensboro, NC 27408, United States
    $150
    • OBO
  • Location Greensboro, NC, 27408, USA
  • Compatibility
Make Model Year
Mini Any Model 2014 - 2022
Fits all B36/B38/B46/B48/B48E Engines
Used for about 2 months.  In original packaging.
Qty 1 Left
FREE SHIPPING in the USA
Dinan
Part # D440-0012
DINANTRONICS Sport Maximum Gains (B48): Up to 30 HP, 40 lb-ft of torque. DINANTRONICS Sport Maximum Gains (B38): Up to 20 HP, 40 lb-ft of torque. DINANTRONICS Sport is the boost controller for the masses. Its simple design/execution allows for easy installation/removal that can be performed in the blink of an eye and yields results you will be sure to feel and enjoy, from the get-go. Coupled with Bluetooth capabilities right out of the box that allows for user-controlled adjustability and a live boost monitor to keep track of the action its a value proposition that is unequaled in the marketplace. DINANTRONICS Sport plugs into a single sensor which lends itself to very quick and discrete installation, or removal, should the need arise. Not only does this connection method offer a simplified install but also effectively utilizes the factory DME, in tandem with itself, in order to re-map boost, fueling, and timing for optimal performance. Once installed DINANTRONICS Sport enjoys connectivity to various smartphone devices courtesy of its built-in Bluetooth Smart system. From the free app, one has the freedom to reduce stock boost for valet duties or crank up the boost all the way up to the "race" setting for maximum enjoyment... or anywhere in between. Regardless of what setting is chosen, there is a power level for everyone. Also within the app, the end-user has access to a live boost monitor which streams boost data in real-time to the phone very similar in appearance to the sport gauges on the iDrive. Not only will you be able to feel the difference but now you can see it as well! Perhaps best of all, the unit automatically detects which engine it is installed upon and loads the appropriate mapping. Effectively making a single unit compatible with an extremely wide range of applications making switching to a new vehicle, sharing with another, or selling the unit a breeze.
Features:
  • Up to +30 HP and +40 lb-ft (B48), Up to +20 HP and +40 lb-ft (B38)
  • Bluetooth smart (Android and iOS Compatible - Android OS8 "Oreo" not supported)
  • Live boost monitor
  • Multiple power settings to choose from (Sport, Sport+, and Race).
  • Valet / parental control modes (-3 PSI)
  • Quick, easy, and discrete installation
  • Automatically detects engine type and loads appropriate mapping
Old May 3, 2022 | 10:23 AM
rsangole's Avatar
rsangole
Dinan Sport Unit
--- edited out! ---
