MMI Apple CarPlay
Audio Video/Electronics
  • Audio Video/Electronics - MMI Apple CarPlay - Used - 2017 to 2021 Mini F60: Countryman - Greensboro, NC 27408, United States
    $450
  • Location Greensboro, NC, 27408, USA
  • Compatibility
Make Model Year
Mini F60: Countryman 2017 - 2021
MMI Apple Car Play PRIME
Compatible with All F-series cars.  If you have a NON nav car without CarPlay, this is the unit for YOU!!!
Originally paid 649.00
Selling for 450.00 shipped in the US
  • Wireless Apple CarPlay
  • USB multimedia and charging port
  • Full-Screen Mode
  • Easy control with
    iDrive
     and Siri
  • Wireless Android Auto support
  • Supports Front and Rear View Camera retrofits
  • High-quality audio with an equalizer
  • Works with your existing iDrive screen (screen pictures for illustrative purposes only)
  • The installation is completely plug & play and 100% reversible.
 1. Wireless Capability
CarPlay MMI Prime lets you connect your iPhone wirelessly. After pairing your iPhone and CarPlay MMI once, the MMI will recognize your iPhone each time you get in your car and connect wirelessly, without you even having to remove your phone from your pocket or bag. When using CarPlay you’ll be able to answer calls just like with a Bluetooth hands-free connection.
If you'd rather connect your iPhone with the use of a cable, you are also free to do so. CarPlay MMI Prime supports both wired and wireless phone connections.
   2. USB multimedia and charging port
Our CarPlay solution comes with a USB port. It lets you charge your iPhone on longer drives, or you can use it for playing videos and music on your iDrive Screen from a USB thumb drive.
The MMI's USB port can also be used in the future for software updates. So, if you won't be using it for charging or multimedia playback — make sure to place it in an accessible location.
   3. Full-Screen Mode
CarPlay MMI Prime lets you use all your favorite CarPlay-compatible iPhone apps on the original BMW display in full-screen. The retrofit's 1280x480 resolution for big screens and 800x480 resolution for small screens look great on all screen sizes.
Note that in MINIs with a rounded screen, a small part of each corner of the CarPlay interface will be obscured when using full-screen mode.   4. Easy control with iDrive and steering wheel buttons
To navigate the CarPlay apps, you can use Siri (with a press of the voice command button), the iDrive controller or even the steering wheel buttons, including the roller button.
   5. Android Auto support
The kit contains a Multimedia Interface (MMI) — a module that also adds Android Auto to your MINI. So if you have family members or friends with Android smartphones, connecting their devices will be a breeze too!
 To enjoy Android Auto wirelessly your phone has to support the wireless Android Auto. If it doesn't, you'll still be able to use the Android Auto via USB — just make sure you have the Android Auto app installed.
   6. Integration with Front and Rear View Cameras
The MMI module makes it easy to add front and reversing cameras to your order for a much lower price. The front view camera can easily be activated by holding the Option button for 2 seconds. To exit camera mode, just press Back. It can also be set up to appear automatically for up to 20 seconds when shifting from Reverse to Drive.
   7. High-quality audio with an equalizer
The audio output circuit in the CarPlay MMI Prime has been specifically selected to squeeze all the quality we can out of the iDrive AUX input, providing great audio quality for music, streaming and calls.
 NOTE: CarPlay MMI Prime uses AUX input to transfer audio over to your MINI’s speakers.
With its user-friendly and instinctive interface, CarPlay MMI Prime makes it easy to use many of your iPhone's apps, including Apple Maps, Google Maps, Waze, Tidal, Spotify, Podcasts, Messages, WhatsApp and more all on your car's native dashboard screen. We've also listened to your needs and given you the option to connect your iPhone wirelessly with your car. For maximum convenience, control and switch between apps with your voice thanks to Siri at just a press of a button.
BimmerTech's CarPlay MMI Prime upgrade is compatible with F-Series MINIs with newer iDrive generations (e.g. ENAVEVO, NBT EVO ID5/ID6). It also features Android Auto which you can use on your iDrive screen either wirelessly or with the MMI's USB port. If your phone supports wireless Android Auto, you can definitely enjoy the wireless capability. However, in case your phone is not compatible you'll still be able to use the Android Auto via USB as long as you have the Android Auto app installed.
Made by Bimmer-tech.net
Old Jun 20, 2021 | 08:02 PM
Kerbouchard's Avatar
Kerbouchard
Do you have the rest of the cables for the install? It looks like at least one is missing in your pictures.
Whats the reason for selling?
thanks!
Old Jun 21, 2021 | 08:17 AM
slimjimtell's Avatar
slimjimtell
Yes, I have the last Cable…good catch~!!!! The last cable is the digital cable that goes from the MMI to the screen.
I am selling it because I sold the 2017 countryman that this was in. I now have a 2020 JCW countryman with apple car play and the full nav. So there is no need for it.
Old Jun 21, 2021 | 09:31 AM
Kerbouchard
PM’d, thanks!
Old Jun 21, 2021 | 02:04 PM
slimjimtell
