MINI Cooper S carbon deposit blaster adapters
For SaleEngine - Intake/Fuel
Price
$10
- Location Alexandria, VA, 22312, USA
- Condition New
- Compatibility
| Make | Model | Year |
| Mini | R56: "Mk II" Mini Hatch/Hardtop range | 2007 - 2010 |
Have a sluggish MINI Cooper S with the turbocharged N14 engine that needs the carbon buildup walnut blasted off the valves? Here is a set of adapters that can be used to connect a shop vac directly to the head to make it a quick and clean job!
What is the diameter at the ShopVac end?
You bolt them to the head at the intake ports, attach your shop vacuum, then stock the blast nozzle through the smaller hole. They help keep the walnut blast material from spraying all over your engine bay.
