ProMeth 3Gal Methanol Tank
Engine - Power Adders
  • Engine - Power Adders - ProMeth 3Gal Methanol Tank - Used - All Years Any Make All Models - Paso Robles, CA 93446, United States
    $200
    • OBO
  • Location Paso Robles, CA, 93446, USA
  • Compatibility
Make Model Year
Any Make Any Model Any Year
I'm moving over to Aquamist's low profile methanol tank so I will no longer be needing this guy. It mounts flat but I have it on end in the photos as I hadn't finished draining it just yet, includes the mounting bands. Has a sight gauge installed and is pre-drilled for an Aquamist flow level sensor. The tank has a rear facing sump and has threads underneath to mount the pump to directly to the bottom of the tank simplifying install.
Old Feb 12, 2021 | 04:38 PM
Serafin's Avatar
Serafin
Which outlet ports you have? Push connect or npt.
also. Will my snow performance pump and floater / leveler work with this? And what’s the lowest. Shipped to 33714 St. Petersburg FL. ?
brand new $225 here
https://weaponxmotorsports.com/produ...iant=242286200
Old Feb 12, 2021 | 05:44 PM
Cab00se's Avatar
Cab00se
brand new $225 here
Dang that's a good savings, well add $20 for the sight gauge but still good savings. This tank was ordered with 3/8 NTP fittings. As far as your pump compatibility, I honestly couldn't tell you. I'd recommend reaching out to Prometh as I was using mine with an Aquamist and needed 90's coming out of the pump to be able to attach lines.
Regarding pricing, for your zip (coming from 93446) with a rough guestimate of packaging size and weight (20x14x11 ~5lbs) you'd be looking at ~$30 for UPS ground. I'll take $160 plus shipping, figure that's ~$100 off retail once you factor in taxes for a box that's held a 50/50 mix of distilled water/methanol.
Old Feb 12, 2021 | 08:01 PM
Serafin's Avatar
Serafin
Thanks fir the quick reply. I’ll reach out SP and see what they say. And yes. Let me think about your offer.
let’s see if my leveler and pump works first.
this comes with a one way vented cap?
Old Feb 13, 2021 | 07:28 AM
Cab00se's Avatar
Cab00se
Yes it includes the original vented cap.
