DSM Hard Top w/ Lotsa Mods
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - DSM Hard Top w/ Lotsa Mods - Used - VIN WMWRE33515TL15149 - 324,350 Miles - 4 cyl - 2WD - Manual - Coupe - Gray - Austin, TX 78738, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $4,000
    • OBO
  • Location Austin, TX, 78738, USA
  • VIN WMWRE33515TL15149
  • Mileage 324,350
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Coupe
  • Exterior Color Gray
2005 DSM R53No Rust
New Mexico Car
 Work done by prior owner:
Valeo Clutch, Water Pump and thermostat, Kenwood stereo system, Hotchkis adjustable sway bars (front and rear) with links, Positive Steering Response System (PSRS), New Crank pulley, JCW Tune, Roof rack w/ bike racks
 Work done by Luke's Garage:
Radiator, Silicone Hose all around (red), Serpentine Belt, pulley and tensioner w/ Alta adjustable tensioner stop, Alternator, Intercooler boots, Supercharger service, Oil Pan Gasket Has welded in baffle, Oil Cooler gaskets and hoses, Crank sensor O Ring, Bypass valve, MAP sensors (both), Vent/Purge valve and pipe, Spark Plugs, Wires, MDS Ignition Coil, Battery, Power steering fan, Fuel Pump, Rebuilt BC Racing coilovers (all around), New Camber plates, Sway bar links, Inner and outer Tie rods w/new boots, Skid Plate, Hawk Brake pads and rotors (all 4), Wear sensors, Wheel Studs, New tires, New tachometer, New driving lights, New grille and scoop (black)
Needs: windshield, motor mounts, coolant tank (included, needs installed), and wheel alignment.
Old Apr 14, 2021 | 09:54 PM
Aindrid's Avatar
Aindrid
holy ****! 324k miles on it! very impressive
Old Apr 15, 2021 | 11:09 AM
Minifenrir's Avatar
Minifenrir
That is a damn good looking mini for 324k miles.
