2003 Mini Cooper S
For Sale2003 Mini Cooper
Price
$8,900
- Location Willowbrook, IL, 60527, USA
- Condition Used
- VIN WMWRE33433TD61881
- Mileage 82,574
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Hatchback
- Exterior Color Blue
Listing my 2003 Mini Cooper S (R53) up for sale. The car is in great condition overall. Has some minor flaws you would expect for the year but nothing that really stands out. A lot of maintenance done with all new parts, list will be below in the description. Feel free to message me with any questions or offers.
My price is $8,900.
Bilstein B4 OE Sport Shocks & Struts Kit
Ball Joint - Left, Febi
Ball Joint - Right, Febi
Lower Control Arm / Wishbone Bushing With Brackets, Rein
Lower Control Arm / Wishbone - Left, MTC
Lower Control Arm / Wishbone - Right, MTC
Ball Joint Outer x2, Lemforder
Guide Support / Front Strut Mount x2, Lemforder
Guide Support / Rear Shock Mount - Left With Bushing, Hamburg Tech
Guide Support / Rear Shock Mount - Right With Bushing, Hamburg Tech
Sport Springs H&R Set
Strut Tower Reinforcement Plates, Hamburg Tech
Crankshaft Seal - Rear Main Seal, GENUINE MINI
Shifting Cable Selector Shaft, GENUINE MINI
Gasket For Oil Housing, GENUINE MINI
Gasket Seal (Connects from the oil filter housing to the heat exchanger), GENUINE MINI
Oil Filter Cap O-Ring, GENUINE MINI
Oil Filter Kit, GENUINE MINI
Stage 1 MINI Cooper S Clutch Kit, Clutch Masters
Lightweight Aluminium Flywheel, Clutch Masters
Rubber Mounting x4 (Mount for power steering pump), GENUINE BMW
Rubber Mount - Top Right Radiator, GENUINE MINI
O - Ring Seal For Crankshaft Sensor, Victor Reinz
O - Ring For the bottom of the dipstick tube, Victor Reinz
Upper Engine Mount Bushing Holder, Hutchinson
Lower Engine Rubber Mount, Hutchinson
Engine Mount Connects and dampens the engine, GENUINE MINI
Serpentine Belt, Gates
Oil Pan Gasket, GENUINE MINI
P/S Pump Cooling Fan, SPAL
ABS Speed Sensor Front x2
Rear Adjustable Camber Arm, Dorman
Exact-Fit Stainless Steel Brake Lines - Kit, ECS
Cat-Back Exhaust System Non-Resonated R53 MINI Cooper S, Milltek
Rotiform RSE Silver x4
Nexen N'Fera SU1 215/40R17 87W Performance Tire x4
Reupholstered Headliner Custom
