Suspension TSW Springs and LCW
Old 03-23-2018, 02:19 AM
tag1260's Avatar
tag1260
tag1260 is offline
TSW Springs and LCW
Do you need to change the LCAs when using the TSW springs? They only lower about the same as the JCW springs, from what I've read, and they(JCW) use they stock LCA's. Don't want to eat up tires. Thanks
Old 03-23-2018, 03:26 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,715 Likes on 1,382 Posts
From my tease arch, you don’t “Have” to get adjustable arms, but if you want to get better alignment numbers you should. Even with a little bit of lowering, you will end up with about 2 degrees camber in the rear. Seems like you want between 1-1.5 in the rear, and 1.5-2 in the front to get the best out of the suspension in the Mini.
Old 03-23-2018, 04:29 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Pretty sure the JCW springs are a 10 mm drop where Way's TSW are 20 mm.
Don't know too much about that newer fangled Gen2 but they may have the adjustable RCA that the facelift Gen1s have.
Old 03-23-2018, 06:49 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
There is some adjustment in the lower control arm, but only about ±0.5°. The aftermarket arms allow for ±4°.
Old 03-24-2018, 04:11 PM
mbwicz's Avatar
mbwicz
mbwicz is offline
The drop will not affect camber a tremendous amount. You won’t tear up your tires driving to the alignment shop. Get it on a machine and see what the numbers are. See the least amount of camber your tech can get, if you are less than -2.0, you should be fine. As stated above -1.5 may be ideal. I’ve seen some people need LCA, others don’t. One way to find out.
Don’t forget to trim your bumpstops. You want at least 1-1/4 in of bump travel in the rear before you hit the bump stops, or you will regret the change.
Have fun,
Mike
minintrigue
03-03-2015 09:50 AM
minimarks
Suspension
38
08-06-2014 10:34 PM
dwf137
Suspension
69
07-20-2009 03:12 PM
tr6drvr
Suspension
10-21-2008 05:57 PM
Quick Reply: Suspension TSW Springs and LCW
