North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   Help - my brake lights won't turn off (https://www.northamericanmotoring.com/forums/stock-problems-issues/98186-help-my-brake-lights-wont-turn-off.html)
Squirrel Apr 15, 2007 03:15 PM
I have an '04 MCS. Today I was driving back from an auto-x event and a buddy told me my brake lights were on constantly. They were working fine this morning on my way there.
I searched the forums and found threads for brake lights that weren't working at all, as well as just the third light lighting up. Both of those were chalked up to a faulty BC1 module. I didn't find anything for this though.
I looked under the brake pedal to see if there was a switch down there that might have gotten stuck, but I'm not really sure what I'm looking for.
Any ideas?
ZigZagN Apr 15, 2007 04:46 PM
Grab a flashlight, craw in under the steering wheel and look up under the dash along the brake peddle arm.
Somewhere there, should be a brake light switch.
Typically these are attached with a plastic rod that actuates the switch anytime you press the peddle.
Most likely this plastic rod has broken or slipped out of it's attachment.
ScottRiqui Apr 15, 2007 05:04 PM
The brake light switch is on a mounting bracket, fairly high up and on the cabin side of the pedal, not the firewall side. It's #11 in this pic.
Yo'sDad Apr 15, 2007 05:07 PM
I don't know what the arrangement for your 04 is, but on the 06, the switch will move back and forth to make the fine adjustment. It it is this arrangment, then a little movement of the switch will fix your problem.
YD
Squirrel Apr 15, 2007 08:04 PM
Seems simple enough - I'll check out the switch first thing in the morning. Thanks for the help!
:thumbsup:
Squirrel Apr 19, 2007 08:04 AM
Turns out it was a faulty brake pedal switch after all. My dealer fixed it under warranty. Thanks again for the advice!
tomthumb195 Mar 25, 2025 03:56 PM
Separate about brake lights and diode
Any ideas?
see https://www.northamericanmotoring.co...s-stay-on.html
