Loud Clunking Shifting Into 1st Gear
Hey Guys,
So I've been experiencing a rather disconcerting issue. Whenever I am stopped and shift from neutral into first gear, there is a loud clunk/crunch that I can even feel from it shaking the car. It does not happen all the time, but it is happening more and more often and occurs more after a long drive and the car has been warmed up. I've been having this issue the whole summer and took it to a highly rated independent Mini mechanic and they thought it was the clutch and the throwout bearing and bearing guide. So I had a complete clutch kit put in with a brand new dual mass flywheel and new bearings and all. Unfortunately, the problem still remains. I found one other thread on here that discusses this problem and the OP has almost the exact same symptoms as I. His thread just got somewhat side tracked and most recommendations were a new clutch/TOB, which I have already done. Here is the link to the thread: https://www.northamericanmotoring.co...e-sitting.html His specific descriptions that almost exactly match my symptoms are:
Thanks guys!! I want my car to be smooth again. https://cimg1.ibsrv.net/gimg/www.nor...93611829fa.jpg https://cimg2.ibsrv.net/gimg/www.nor...33b838d304.jpg |
Other possible causes I have found from doing research is: play in the drivetrain, like the CV axle/joint? The diverter valve?
Anyone? Help?
Wishbone rear control arm bushings
Originally Posted by EintrachtAdler
(Post 4484489)
Anyone? Help?
check them by kicking your front wheels in direction of the car (forward or back, either direction) there should be no lateral movement at all... I could grab my front wheels with both hands and move them about half an inch just with my strength. https://cimg2.ibsrv.net/gimg/www.nor...67a98e97b.jpeg |
Originally Posted by Steve16190
(Post 4484515)
Hey dude, on my R53 I had clunking when I first got it changing into first and second gear mainly, and coming off the gas/dropping the clutch sometimes. Turned out to be my rear control arm bushings shot to hell. The jolting on gear change was the play in the bushings (which should be rigid and not move at all). The change in drive/brake momentum made it clunk exactly like you’re describing. Stiff as a rock now since replacing them.
check them by kicking your front wheels in direction of the car (forward or back, either direction) there should be no lateral movement at all... I could grab my front wheels with both hands and move them about half an inch just with my strength. https://cimg2.ibsrv.net/gimg/www.nor...67a98e97b.jpeg Hey thanks! That would make sense and I do hear something on the drivers side when going over bumps. I tried taking a video of me kicking the tires. What do you think? It’s kinda hard to see since the camera shakes as I kick but there definitely is a little movement. |
