06 MCS no start
I have a 2006 MCS conv. that has me pulling out my hair. Bought it and drove for about 1 month then radio stopped working(shows disabled) then top would no longer go down then no dash lights all over 1 week. Then it started and died and would no longer start. Replaced bcm after doing some research and reset computer. No change. Checked and cleaned body grounds with no results. No codes on scanner all fuses and relays good. Also key stopped locking unlocking reset and worked to lock/unlock for a few minutes. Also checked battery which is good. No moisture in car. also new crank/cam position sensors. Any help would be appreciated
Have you flipped the engine fuse box over and checked the connections? Would need to remove the ECU and airbox in order to flip. Jumper post next to airbox have voltage?
Thanks for the input. Voltage at post is good and all connections appear to be fine. I will put it back together and see if checking has any effect. Wondering if rolling key code being out of sync could have this effect if that is even the case with mini.
Have you verified that when you turn the key the starter is getting voltage? Was a recent post where the switch was bad.
I see I did not mention cranks with no spark so starter is getting voltage. I really am at a loss with this car. I just ordered the usb to obd2 and downloaded the inpa software. Hoping that gives some insight.
Originally Posted by fseater
(Post 4354884)
...Also checked battery which is good....
A failing or failed battery can still show 12 volts, but not have the capacity to properly support full electrical function on a MINI, potentially exhibiting electrical inconsistencies like the ones you are experiencing. |
Yeah one of the first things was to test at a shop. Tested at 60 CCA. Bought a new battery just to see if it had any effect regardless but no change
