screech in first gear
When I start off in first gear in my 2003 Cooper S, especially when cold, I get a screech from the drivetrain. No clunks or vibrations, just a not-very-high pitched screech that lasts until the clutch is fully engaged and the car is rolling - less than a second. Anybody have any experience with this?
Sounds like the throw out bearing or the fingers from the clutch plate hitting the bearing.
https://www.northamericanmotoring.co...of-travel.html |
How many miles? Could be your clutch is worn and the rivets are hitting the flywheel.
I have a serpentine belt that has started to screech for the first couple of 1st gear starts when cold, but as the belt warms it goes away, just a little reminder to replace it with my next Oil service.
Motor On! |
Thanks for the replies. I put in the small s/c pulley with new belt not too long ago. Of course I can't remember if it screeched before that or not, but it certainly didn't screech immediately or I might have put 2 and 2 together . . .
I'm going to somehow listen for the screech under the hood as my son starts off in first gear (why do I feel this might be my last post?) to test the belt theory, but I'm leaning toward the clutch guide tube theory. But then, why only starting off in first? I hope to let you all know what I find . . soon |
(Post 4315015)
https://www.northamericanmotoring.co...of-travel.html Is the acceleration a little "bouncy" feeling? Does it screech louder/chirpier if you dump the clutch? Especially if you added a pulley, and now you're experiencing a screech, I think the tensioner is a better (and far more likely) first step. |
Originally Posted by Sandy03
(Post 4314999)
New tensioner with new belt and new pulley . . .
I'm still trying to figure out how to get my ear under the hood when the clutch is engaged in first gear without getting killed . . . oh . . . jack stands . . . I'll try it Monday . . . |
(Post 4315317)
(Post 4314999)
It's been this way for three years. I wouldn't worry about it. |
I've personally seen what happens when a TO bearing issue is ignored, I can tell you it's not a pretty sight....and gets expensive.
Found this, good read: https://www.northamericanmotoring.co...nsmission.html |
And here too: https://www.northamericanmotoring.co...gh-casing.html
Originally Posted by sarom058
(Post 4315248)
^^ Yeah...that, or just a worn belt tensioner. :lol:
