Has the part price for a HPFP jumped since 2yrs ago???
Hello all
I own a 2010 convertible S w/ 63k miles on it. This has possibly been the cutest mistake Ive ever made. I know that the HPFP extended warranty covers 2007-2009...but why not 2010 when its the very.same.part.? When looking at thread entries from 2014/2015 I saw that part going for 250-350...now when I look BOOM! 1000 or more..are you kidding me?? After further digging and calling around, I was told that VDO made a deal with Mini and now MIni has a monopoly on the dang part, you know they are getting it for hardly nothing while the rest of us poor saps either have to get it from them or get the part from some retailer for just a little less...a little. I was checking out a couple of salvage yard pieces , one from a 2007 (91k mls) and one from a 2010 (63k mlk). Im nervous about the 2007 one since, well that was one of the years covered by the extended warranty If anyone could give me a heads up on where I can buy the part for considerably cheaper and/or give me input on the used parts I was looking to possibly buy....that would be awesome. Thanks! =0) Or if anyone is starting or knows about a class action suit for the HPFP 2010 + please let me know. I hate my car. |
Be careful about the replacement fuel pump - I've been told by a reliable source that there are differences in the HPFP's over the years.
Are you certain that your HPFP is the problem? |
Originally Posted by bugeye1031
(Post 4308584)
Are you certain that your HPFP is the problem? -changed out coils and plugs -got a fuel injector clean And I gave em a laundry list to check..including injectors and they are saying its the HPFP...but do you get a strong gas smell with that on cold start? |
Yes, check the low-pressure pump, carbon build up on the intake side of the head, and then the coils / plugs. Then go to the HPFP. Yes it went up because they had it at pretty much a warranty replacement price then it shot up. We have some in stock.
https://www.northamericanmotoring.co...r-r56-jcw.html |
(Post 4308990)
https://www.northamericanmotoring.co...r-r56-jcw.html The coils and plugs have been replaced on my own. was still getting misfires on all cylinders. Also did a fuel injection clean. Finally took it into the crooks (Mini Service) they have it for a week to "diagnose" and when dropping it off I gave them what I had done previously to help with guesswork and what Id requested for them to check: -HPFP -intake valves -valve springs and seals -all cylinders -gaskets -re-check the timing chain that they recently replaced. (extended warranty) -mass air flow system/air filter (was getting codes) When they finally call me they say its the HPFP with piss poor explanation and didnt even check the other stuff "you gotta replace the pump first before we can check to see if anything else is wrong...you dont say..really??). Said that the misfire codes were caused by "low fuel rail" but only said that the HPFP needed replacing. When I looked at the estimate which they finally gave me after some bitching I saw: -HPFP-1253.99 -pressure hose -63.99 (ok...is that really needing replacement? is it leaking??--that question wasn't answered yet) -feed line- 169.99 (again, is this leaking?) Could bad lines to the HPFP be the cause? if the fuel transfer is disrupted would it cause issues with the pump which would provide misfire codes? Could this be a matter of just not being lazy POS and seeing if they are leaking? if not, then why are they calculating that price into the estimate? |
If it isn't going to be covered under an extended program by MINI, you might as well have an Indy mechanic do the job. They probably won't need to replace the hose/line. I think MINI does that because it is a liability issue and they don't want call backs on leaks if the parts don't mate correctly or develop a leak down the road.
My 2011 threw codes related to Fuel pump, so I knew going in what it was and that I was covered. |
Originally Posted by Minnie.the.Moocher
(Post 4309127)
My 2011 threw codes related to Fuel pump, so I knew going in what it was and that I was covered. It is at a indie mechanic. But remember I have a strong fuel smell with hard cold start as well...a failing HPFP doesnt produce a gas smell...hence me asking about a leaky line/hose |
Maybe you need the dealer or a different mechanic?
If the HPFP is bad and the tank fuel pump is pumping gas, then it could be leaking somewhere along the line and causing a fuel odor. I'm just guessing on this! The well trained modern BMW/MINI mechanic works off the flow chart diagnosis q&a that is in the software that they use to diagnose problems. Can't replace C unless you've done A & B, which can add up to lot's of dollars. Can be very frustrating. |
So what happens if you don't replace the HPFP? Do you just lose the use of the turbo and is it like you're driving a base model instead of an S?
Another price increase is the engine is out of production. The after production price always bumps up significantly. Working for a tier 1 ho made pumps th production cost really goes up.
1: We built a bank of parts and moved the line to a separate building. $$$ 2: That building had all parts support lines for non current production. In full production you may have had 3 or 4 lines now you have 1. 3: runs have to be done to requalify the moved line 4: you have to keep a crew trained to run it and order parts in low volumes from your suppliers who are all doing the same thing. 5: You have a line that is highly automated taking up a huge chuck of floor space hat requires maintenance and gets run about once a month. The whole part costs allot more. We do not like it but it does. |
Originally Posted by MiniMAD!
(Post 4309107)
-HPFP-1253.99 -pressure hose -63.99 (ok...is that really needing replacement? is it leaking??--that question wasn't answered yet) -feed line- 169.99 (again, is this leaking?) Could bad lines to the HPFP be the cause? if the fuel transfer is disrupted would it cause issues with the pump which would provide misfire codes? Could this be a matter of just not being lazy POS and seeing if they are leaking? if not, then why are they calculating that price into the estimate? That's funny. My dealership told me that they no longer replaced the HPFP hard lines as part of the repairs. No idea why they would replace the hose though. After I voiced my concerns over the price increase and not being included in the HPFP warranty extension, they sent my information to MINI USA and was told to cover 50% of the repairs, which still equaled ~$750.00. Still more than I feel I should pay, so I'm keeping other avenues open. If you're feeling adventurous, you could try this HPFP on ebay. http://www.ebay.com/itm/182475261414 |
Originally Posted by Cngizbleevng
(Post 4309213)
It will only have ~200psi of fuel pressure, or even less, when it needs between 700psi at idle and up to 1,800psi when driving. You'll have cylinder misfires. Lean conditions. All kinds of trouble. |
$750 sounds like a good deal. eBay has them new from $500-$800 and even over a $1000.
Originally Posted by sikamini
(Post 4309501)
And I still feel like the 2010 models should be included in the warranty extension, since the part number for the pump is exactly the same as the models that are covered. So I should be paying $0 really. |
I wonder what it really cost to manufacture the HPFP.
I wonder why 2007-2009 are included, and I got a notice recently extending the warranty on my 2011 for the same as the 2007-2009, but 2010 is NOT included? Odd, for sure. I would press MINI on this fact alone!
Btw... If you are in Europe you can get the HPFP pump from Peugeot (P/N 1920LL) for about 400eu or £360. There are a lot of people on German forums that did the swap and it works brilliantly. The pumps appear to be identical.
Btw.. we were just able to get the Genuine PSA N14 part for you guys but it's a little time to come in. Linked below. We are working on getting it sooner, but right now that is the time frame. Hold tight. We do have the Genuine MINI ones right now in stock at a lower price since last month.
https://www.ecstuning.com/Search/SiteSearch/13517588879/ |
What company is PSA?
Genuine Peugeot / Citroen parts, that's what the call it over there.
Great News! Thanks ECS!
Welcome. This is how it feels to find some parts for MINIs and then when you find them.
https://cimg8.ibsrv.net/gimg/www.nor...185bcbbe87.png |
I LOVE the part description...
"This HPFP is mounts to the fuel system and transfers fuel" hahahaha I got a chuckle out of that :-D |
Thanks for pointing that typo out. Looks like a glitch on the front side of the system.
Oh I wasn't even worried about the typo. I just thought the description was funny. Of course a fuel pump transfers fuel! :-D
