North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   Preparing to replace the clutch on my R53, what else to do while it's apart? (https://www.northamericanmotoring.com/forums/stock-problems-issues/315154-preparing-to-replace-the-clutch-on-my-r53-what-else-to-do-while-its-apart.html)
silence2-38554 May 18, 2017 10:34 AM
I have the Valeo clutch kit, rear main seal, transmission input seal and throwout bushings. Is there anything else, even outside of the transmission that should be taken care of while I have access? How about the transmission mount? I've replaced the other two engine mounts but this one seems to be rarely mentioned.
I'm at just under 100k miles. The starter & slave cylinder both seem to be fine. Anything else I should check?
JABowders May 18, 2017 12:45 PM
I would recommend an inspection and replace anything that appears to showing age.
A good time to do a good cleaning as well...
Best of luck.
Motor On!
Rich.Wolfson May 18, 2017 07:37 PM
Originally Posted by silence2-38554 (Post 4302290)
...Is there anything else, even outside of the transmission that should be taken care of while I have access? ...
I'd say go for a LSD. I made the mistake of not doing that and have regretted it ever since.
///Rich
MSFITOY May 18, 2017 07:40 PM
Install a Quaife LSD
silence2-38554 May 18, 2017 09:28 PM
I probably won't be able to throw an extra grand at the project for a Quaife haha
ECSTuning May 19, 2017 06:49 AM
Check the guide tube also and or replace it. Mine was grooved pretty bad and the throw out bearing was getting a little hung up on it.
https://www.northamericanmotoring.co...-flywheel.html
https://cimg7.ibsrv.net/gimg/www.nor...8317c4d904.png
And if you can do it go for an LSD. The bearings are listed at the bottom of the link. ES277056.
https://www.ecstuning.com/Mini-2005-Cooper-R52-S-Convertible-L4_1.6L_W11B16A/Drivetrain/Differential/
Yellowducman May 19, 2017 07:33 AM
I just did mine. I also replaced the Crank Position seal, Control arm bushings, power steering return lines, sway bar bushings, throw out bearing shaft bushings, belt, belt tensioner, idler, oil cooler o'rings, rear main seal Plus a bunch of little things.
The whole car is pretty much disassembled. Might as well have a good look and replace everything while it is easy to get to.
ItsmeWayne May 19, 2017 10:32 AM
You should think about replacing the clutch hydraulic system, as at some point it will fail.
silence2-38554 May 19, 2017 08:00 PM
Good call on the power steering lines, I will take care of those while everything's apart. I'll take care of the guide tube as well. Thanks for the suggestions!
ECSTuning May 22, 2017 08:35 AM
Welcome.
MSFITOY May 22, 2017 01:37 PM
I was in the same boat upgrading a clutch and when I learned the labor to open up the trans was nearly a grand, well I didn't want to pay that again just to install a diff...you should consider this:thumbsup:
