Originally Posted by nkfry
(Post 4255215)
This is what I'm getting at. You will have a round about answer on what the failure is and where to start your diagnostic.
I will pass along your information to the office folk and have them send you a quote Banyan. :thumsup: |
compression test only shows what is going with cylinders.... so to be more precise a leak down test can be don easily then it will show or you can hear air escaping from intake or exhaust valves.... a typical valve job will cost around 250 ish. If you are handy the head replacement job is very easy.
Originally Posted by PhoR53
(Post 4255643)
Now my next question is regarding the cam holding tool. Is this tool neeed if all that I will be doing is replacing the head? or is this tool needed to prevent the cam from rotating while torquing the cam sprocket bolt? Any idea how to remove and install the cam sprocket without the cam holding tool? my car is R53 automatic. |
get the tool and it costs only 33bucks on ebay. Worth every penny. It will assist you during the removal and installation procedure with ease. Torque everything to specs. Buy some engine assembly lubes. While removing the rocker arms be very gently so that the "tip" on them won't fall off
Good point on the cam holding tool.
I received the leakdown tester today and found that the adapter hose that came with it that connects to the spark plug hole has a Schrader valve. Is this correct? Shouldn't this adapter hose be a straight through hose? I do know that the adapter hose for a compression tester has a Schrader valve but I was not expecting the leakdown tester to have an adapter hose with a Schrader valve. |
Yes,thread one end in the plug holes,then one will attach to air compressor (set it at 110psi). Set the pistons or cylinders at TDC (with a 1/4 extension or whatever so that you can tell its at tdc). Result of each should ve less than 10%,above means leakage
(Post 4256002)
Originally Posted by banyan
(Post 4256031)
Thank you. I think I understand the connections but I am struggling to understand how pressurised air will flow into the cylinder when there is a Schrader valve in the hose that is connected to the plug hole.
(Post 4256043)
Same dynamics of a Schrader valve in your tires; allows air in but not out.
just confirmed my suspicion. I have to remove the Schrader valve in order allow air pressure to go into the cylinder. I think they shipped the wrong hose adapter, but still workable after removing the schrader valve. See video below on how one guy converted a compression tester to a basic leakdown tester:
Hey banyan, What did you ultimately do?
Ended up selying it as is. Cylinder 1 was messed up due to broken spark plug electrode and did not have time to work on it |
Originally Posted by Dennis Bratland
(Post 4255146)
I used compressed air to keep valves from falling into a cylinder one time, and it worked, but it was scary. So many things could go wrong. Later I tried the feeding rope into the spark plug hole and pushing it up with the piston, and I felt much better while I was working. This wasn't on a Mini.
Just thought I'd throw that out there. This is the preferred way to do it, and is pretty much foolproof. I have done much engine work using this technique. The compressed air way is OK, but too much can go wrong. One way to improve this is to use natural bailing twine, or jute or sisal string. This way any little fibers that are left will burn up and turn to ash, not potentially get melted onto a ring or cylinder wall. |
