Driver's Door Lock Issue
I'm have been having issues with my driver's side power lock. It works fine manually, but not with the key fob or the interior switch. I searched the forum, it did not come up with much. Anything I should check first?
Thanks |
I would start with fuses but this beats me
Have you checked the lock wiring itself. Also sometimes when the battery on the key is weak or low, the lock from the key fob will not work.
https://www.northamericanmotoring.co...vers-door.html |
Hi i got the Next Problem...
i Can't lock the doors the key fob works to unlock (passengers) the drivers manual way only locks drivers door. and unlocks both doors when i move the button on the lock on the middle dashboard makes a sound to unlock but doesnt work. my main concern is to lock the tailgate or backdoor |
Check the main car battery first, when you have the low voltage all the lock kind of act funny. Check that first and see what the voltage is and if you can load test the battery. Since you are having mutiple items with the lock, also check the footwell module in the driver side floor kick panel, have you had issue with water in the footwell, maybe from water leaking in ?
| All times are GMT -7. The time now is 09:05 PM. |
