FS:: 2006 Mini Cooper R52 S Convertible 76k
Old Sep 11, 2020 | 11:16 AM
Debbieg1245's Avatar
Debbieg1245
Superb clean low mileage Mini Cooper R52 S Convertible 76k. Loaded with performance upgrades. The Big Valve Head is just incredible! Great mid range, and the car screams from 5000 rpm all the way to the 7800 rpm red line! This is a very serious world class Mini. The higher you rev it the smoother it gets. The Vibra Technics motor mounts mean there is no drive line play and no hesitation. When the head work was done, every gasket was replaced while in there. All maintenance has been done including the expensive supercharger service. Both oil and transmission fluids have been upgraded to Amsoil.
List of Upgrades Done in the last year: Revolution Mini Works Big Valve "Jesus" Head - $2750 Revolution Mini Works Dominator Cam - $360 Revolution Mini Works Intercooler w/ Coating - $315 Revolution Mini Works 550cc Injectors - $325 Revolution Mini Works Header w/ High Flow CAT - $1075 Revolution Mini Works Custom Tune & My Genius Loader - $650 Way Motor Works 17% SC Pulley, Belt, & Spark Plugs w/ Installation - $379 DDM High Flow Intake - $239 Gates SC Belt Tensioner - $100 Way Motor Works SC Belt Damper Bushing Set - $30 Way Motor Works Rear Sway Bar - $240 ATI Crank Pulley - $371 Power Flex LCA Bushings - $83 Power Flex Steering Column Bushing - $26 Power Flex Front Sway Bar Bushings - $48 Screamin Demon Coil Pack - $88 Way Motor Works Spark Plug Wires - $50 Mini Exhaust Hangers - $52 New Gaskets Head, Valve Cover, Timing Case, Oil Filter Mount, Crankshaft Sensor, Oil Pump, Oil Pan, Dipstick - $120 Labor for Performance Work plus Supercharger Service - $1230 Milltek Exhaust w/ Resonator - $710 Vibra Technics Engine Mount - $231 Vibra Technics Torque Link - $172 Outmotoring Blind Spot Mirrors - $60 Mini Genuine Floor Mats - $65 Stubby Antenna - $25 New Throttle Body - $174 New Radiator Fan - $217 New Fuel Pump - $159 New Fuel Filter - $60 New MAP Sensors - $190 Total - $10,594 Older Mods: Red Painted Calipers Drilled & Slotted Rotors RSL Ricochet 18" Wheels Factory Equipped Options: Harmon Kardon Stereo| Xenon Headlights Auto Climate Control Fog Lights Multifunction Steering Wheel Controls Clean Title and Clean Vehicle Autocheck Report in Hand. Receipts for all work/upgrades included. 2020 Front struts, new throttle body, oil change, front end alignment which is under warranty. I still have the rear shocks but they are not installed. New tires also. Priced at 12,500
Z06C5R
Jun 19, 2020 06:24 PM
Bradg33
Sep 11, 2012 09:58 PM
Tonefiend
Aug 29, 2010 07:03 PM
