FS:: Mini Cooper S JCW GP1292
Year: 2006
Model: Hardtop
Price: $18000
Mileage: 76852
Color: Thunder blue
Location (Region): NorthWest
For those wondering what happened I had originally advertised her here in Dec 2019, and then pulled the advert as it was going to go up on Bring A trailer. The car had a persistent check engine light and Bring a Trialer rightly rejected the car as it wouldn't pass emissions. In the meantime I relocated to the UK and left the car with my mechanic friend in Portland, OR. So fast forward to today, the check engine light issue (P0172 code) is finaly resolved: Turns out that the car had been tuned with an exhaust leak, when the exhaust leak was fixed the P0172 code got triggered. It sounds realy simple, but it took a huge amount of work to diagnose & fix it, and I'm greatly indebted to my mechanic - So the car since it was last advertised here has had the fuel injectors tested & cleaned, new camshaft sprocket, exhaust and inlet system completely gone through, pressure tested, leak tested, new seals where required. ECU tune reprogrammed by Adrian Nastasecl.
Highlights of the build:
- RMW Big Valve Head & RMW Street cam
- RMW Shorty header
- RMW 440 cc injectors (cleaned & calibrated)
- Way Motor Works supercharger pulley
- JRZ RS double adjustable coil over shocks
- Swift metric coil spings
- Whiteline end links front & rear
- H&R adjustable rear anti roll bar
- Vibra-Technics passenger side engine mount
- Ported & port matched intaker manifold & inlet plenum
- RMW teflon intake gasket & ARP studs
- Colin Green cooling system header tank in black.
- New OEM TPM & TPMS sensors
- New OEM fuel pressure regulator
- New spark plugs
- New Powerflex front lower control arm bushings & steering rack bushing
- Cravenspeed oil dipstick & stubby antenna
- Includes OEM GP car cover
- Car has been regularly maintained by Mini of Portland (oil changes, brake flush)
biglittle
R55 :: Clubman Talk (2008+)
18
Mar 23, 2021 08:15 AM
Drivetrain RMW Turbo kit conversion
Revolution Motor Works
Mar 21, 2020 11:51 PM
Drivetrain Ibiza Cupra R FMIC on the 09 207 RC !!
Antalyalogy
Sep 19, 2009 07:23 AM
