FS:: 2007 R56 manual swapped
Old Jul 3, 2020 | 12:10 PM
GT350's Avatar
GT350
2007 R56 manual well maintained
Year: 2007
Model: Hardtop
Price: $4500
Mileage: 125000
Color: Yellow
Clean title, no accident. 65k Engine, 125k Chassis, located in Central NJ
The original engine had bent valves, replaced the same engine N12 from a part car that had 55k miles (It was also the 2nd engine from the part car that replaced by Mini under warranty in 2013, I have the paper work)
Along with the engine, I swapped the transmission from AT to MT. I have been driving it since 2018 Sept & over 10k without a single issue.
Parts replaced under my ownership, most job done in 2018
- Engine: spark plugs & drive belt & lower engine mount + Powerflex bushing insert.
-Transmission: fluid, new clutch.
-Suspension & brakes:
1.JIC cross coilovers w/ Alta end links, camber adjustable - absolutely a go-kart, can autox or track after a brake upgrade.
2.Timken front wheel bearings x 2
3.Front & rear rotors (Centric) & Pads (stoptech)
4.Stoptech F& R stainless steel brake lines & brake fluid flush
5.F& R sway bar end links & Rear sway bar bushing
- Interior
1.Replaced cloths front seats to OEM leather seats
2.JCW shifter
3.dark chrome trims and some Alcantara wrap
- Exterior
1.F56 looking HID headlight
2.2011+ rear taillight & DIY reverse light
3.Rough Country LED light bar
4.Cooper S front grill & spoiler
5. two new front tires (Jun 2021), wheel center caps are included.
- Other
1.Radiator
2.AC condenser
3.Coolant flush
4.Bosch battery (Mar 2021)
The bad
- No ABS, when did the programming during the manual swapped, ABS code can only program once and it was failed.
- Radio can only receive 99.1. The receipt line in the rear window is damaged. Aux cable works can listen Youtube.
dhabutcher
Jul 15, 2019 12:10 PM
bron
Jun 20, 2019 10:52 PM
03aksuby
Apr 14, 2017 09:21 PM
raven9mm
Suspension
42
Mar 14, 2012 06:08 AM
basham
Oct 15, 2007 06:19 PM
