FS:: 2002 JCW Low Miles Well Documented
Old 08-21-2019, 12:22 PM
52Radical's Avatar
52Radical
52Radical is offline
Year: 2021
Model: Hardtop
Price: $7950
Mileage: 53000
Color: Red
Location (Region): NorthWest
NO LONGER FOR SALE I've decided to keep the car and build it into an even more aggressive car.
Low mileage tastefully modified 2002 John Cooper Works Mini Cooper. This car has had 3 enthusiast owners and has been meticulously maintained and thoughtfully upgraded. It has low miles (53K) however, the car has been driven, so doesn’t have leaky gaskets, brittle belts, or bad hoses like some low mile cars. Everything works as it should, and the car drives beautifully and aggressively. I just had the Stoptech front rotors replaced and four new Toyo Proxes R888’s.
You won’t find many R53’s like this one.
Asking $7950 OBO
Engine
JCW Tuning Kit
Cooper Works Super Charger Kit
550 Bosch injectors
Bytetronik FA53 Tuning Kit
ATI super damper
Dinan cold air intake
TMR oil cooler
Mini Madness race flywheel
Metal reservoir bottle
Suspension/drive train
Koni Yellow Struts/Coil Overs
Mini Mania Camber plate, control arms, tower bar
BBC wheels
Oversized wheel studs
Short Shift Kit
Stoptech front braking system (rotors/calipers)
Quaif LSD
Interior/electronics
Mini Mania Roll bar
Wide angle rear view mirror
Heated sports seats (allows Schroth 4 pt restraints)
Tinted windows
Hard wired escort radar detector
Craven stubby antennae
Hard wired for Garmin GPS
Rear seat delete (Have the rear seat)
Innovate Shift light, oil temp, oil pressure, Supercharger Boost Gauges
Mini Mania Auxiliary input
Maintenance in the last 5000 miles or less
Ball joints
Rear wheel bearings
Cooper S Stage 3 clutch
Bosch Starter
Thermostat with housing
Changed supercharger oil and belt (within the last 500 miles)
Suspension bushings
Raybesto front brake pads (lots of life left)
Dinan Air filter
Stoptech brake rotors ( installed August 5)
Toyo Proxes R888 ( new August 5)
Trunk lock
Driver side window motor
Fresh fluids including engine oil, transmission fluid, brake fluid
Attached Thumbnails 2002 JCW Low Miles Well Documented-img_0514.jpg   2002 JCW Low Miles Well Documented-img_0516.jpg   2002 JCW Low Miles Well Documented-img_0507.jpg   2002 JCW Low Miles Well Documented-img_0512.jpg   2002 JCW Low Miles Well Documented-img_0510.jpg
2002 JCW Low Miles Well Documented-img_0509.jpg   2002 JCW Low Miles Well Documented-img_0518.jpg   2002 JCW Low Miles Well Documented-img_0522.jpg   2002 JCW Low Miles Well Documented-img_0520.jpg   2002 JCW Low Miles Well Documented-img_0528.jpg
Old 08-22-2019, 12:58 PM
Colton Ratcliffe's Avatar
Colton Ratcliffe
Colton Ratcliffe is offline
Shes a beauty!
Old 08-22-2019, 01:06 PM
52Radical's Avatar
52Radical
Thanks !
Old 08-23-2019, 12:03 PM
52Radical's Avatar
52Radical
Bump, new price
Paragon
MINIs and Minis for Sale (archive)
06-29-2008 11:26 AM
Tadaidan
02-26-2007 02:14 PM
Quick Reply: FS:: 2002 JCW Low Miles Well Documented
