FS:: Mini cooper with some work needed
Old 05-25-2017, 12:42 PM
Jason Tavares's Avatar
Jason Tavares
Jason Tavares is offline
Year: 2003
Model: Coupe
Price: $2200
Mileage: 168000
Color: Red
2003 Mini Cooper
Red w/ white racing stripes
168k
Misfires on cylinder 3 intermittently, runs smooth when not misfiring
Dealer performed compression/leak down test and said that cylinder 3 was leaking. For a car this age it makes no sense to have the dealer perform this work; however, I don't have the time right now to pull the cylinder head to inspect. Maybe sticking valves? (Though, I am not a mechanic.) For someone who does have some time for a project, this could be a good car.
Here's a list of replaced parts:
165000 Replace fuel injectors
163000 New tires
150000 Replace muffler
142838 Replace brake rotors, pads, rear calipers, LR wheel bearing
130992 Replace right rear bearing
130789 Replace fuel filter & fuel pressure regulator
130000 Replace Windshield
129046 Replace emergency brake cables
129025 Replace Spark Plug Wires
129025 Replace ignition coil
122041 Replace fuel pump
121751 Replace LF wheel bearing
120000 Spark plugs changed
Naturally, having 168k, it has some issues:
Minor leaks:
power steering hose
radiator
oil pan gasket
crank sensor seal
Worn sway arm and control arm bushings
Broken exhaust hanger
Rust below driver's tail light
The only issue that is currently preventing drivability is the misfiring.
I will entertain offers.
Attached Thumbnails Mini cooper with some work needed-img_0080.jpg   Mini cooper with some work needed-img_0086.jpg   Mini cooper with some work needed-img_0081.jpg   Mini cooper with some work needed-img_0082.jpg   Mini cooper with some work needed-img_0083.jpg
Mini cooper with some work needed-img_0084.jpg   Mini cooper with some work needed-img_0085.jpg
