FS:: 2005 Mini Cooper S /// Located in British Columbia Canada
Old 01-07-2020, 12:49 PM
WheelNut's Avatar
WheelNut
WheelNut is offline
Year: 2005
Model: Hardtop
Price: $3300
Mileage: 302000
Color: black
Location (Region): Canada
Selling my R53 I've owned this R53 for about a year and a half. Over the last year I've done quite a lot of maintenance work to the car to get rid of the common R53 weak spots like the PS pump and super charger. No accidents on the Car Proof. There is very early stage rust starting to bubble under the paint just below the right tail light. 2" scuff on the front bumper that will somewhat buff out. This car was garaged for most of its life so the paint is in pretty decent shape. No check engine lights or leaks! 302,000km (180,000mi). Clutch has no issues and is smooth, but I do not know the last time it was changed. No sunroof, so, lower center of gravity, lower curb weight, no leaks, and more head room! Pretty rare to find an S without a sunroof. This car does not have a limited slip differential. If your in Seattle bringing this across the border wouldn't be very difficult.
Car is located in Vancouver, BC, CANADA
$3300 Canadian or $2600 USD
Contact via Email please bradcomis@gmail.com
2005 Mini Cooper S
301,000km (and going up)
VIN: WMWRE33525TL12048
Features:
6 Speed
No sunroof!
Xenon HID headlights
Continental Extreme Contact DWS tires (not worn out)
Clutch is strong
Good AC and heat
Car runs great!
All electronics work
No water leaks
Tire tread depth front 3.4mm. Rear 3.8mm.
Had a compression test done with my pre-purchase inspection last year and all the numbers were in the correct range.
As expected a 300,000km car will have a few things:
Windshield has a large circular crack near the base (which is not spreading)
Driver's seat has some cracking (not ripped through though)
Steering wheel and shift **** show wear
2" scuff on front bumper
Maintenance done in the last year:
New-used supercharger (120,000km unit with new oil seals)
New power steering pump
ALL fluids replaced (engine oil, PS fluid, coolant, brake fluid, transmission fluid)
New water pump
New battery
New SC/accessory belt
New water pump O-rings
New crank position sensor O-ring
New oil pan gasket
New belt tension unit (new damper and roller)
New idler pulley
And more...
Xner
12-16-2019 10:22 AM
AutoCoarsen
11-08-2019 06:45 PM
1FSTREX
10-23-2019 07:41 AM
suddan
07-19-2019 08:41 AM
grahamquanta
05-21-2019 10:02 PM
Quick Reply: FS:: 2005 Mini Cooper S /// Located in British Columbia Canada
