FS:: 2006 Cooper S CRONOPACK, Lots of maintenance. Performance upgrades. Must See - PA
Old 05-21-2014, 08:53 AM
ThatMiNiGuy's Avatar
ThatMiNiGuy
ThatMiNiGuy is offline
Thumbs up 2006 Cooper S Chronopack, Lots of maintenance. Performance upgrades. Must See - PA
Year: 2006
Model: Hardtop
Price: $11500
Mileage: 102600
Color: Chili Red
Selling my Chili Red Supercharged 2006 Mini S(one of the last cars built in Oct 2006), factory option LSD 6spd manual transmission with 102,xxx miles. Factory option Panoramic roof, Xenons headlamps, armrest, heated seats, and rare factory Chronopack 3set gauges. There is less than 800 miles on the new Exedy clutch/flywheel and other tasteful modifications done in the power, cooling, braking, suspension. I'd say almost every maintenance item possible has been done on the car, nothing major labor needed for another 80,000+miles besides the usual oil changes, wear items and tires you'll burn thru.
Asking $11500. All reasonable offers will be considered
Mainenance Items:(most of which was done just because "they were in there and it was apart".)
  • Exedy Clutch and Flywheel
  • OEM Transmission oil change
  • Motul Engine oil change NAPA GOLD filter
  • OEM belt tensioner and shock
  • Accessories/Supercharger belts
  • New oil cooler hose and housing gaskets
  • New lower and upper cooling hoses throughout
  • New crank sensor oring
  • Front and rear main seals were inspected and in tip top shape
  • OEM inner and outter balljoins replaces
  • OEM hydraulic/engine mounts
  • OEM Waterpump
  • OEM Thermostat
  • Upgraded highflow radiator
  • New Coolant reservoir and coolant system flush
  • Screamin Demon coilpack, IE wires, NGK plugs
  • Wheel stud conversion with lightweight Muteki lugs.
  • 2 new Bridgestone tires
Performance add-ons:
  • 15% Helix pulley
  • Helix Short throw shifter
  • AFe CAI
  • Magnaflow Bolt-on SS full cat-back system (not custom)
  • ALTA 4-1 Header
  • ALTA IC Diverter
  • ALTA swaybar endlinks and poly bushings(stock bar)
  • Powerflex Upper mount insert
  • Powerflex LCA Bushing
  • Exedy Clutch and Single mass flywheel(under 800 miles)
  • Mishimoto larger aluminum radiator
  • Factory LSD
  • Factory Sport Package
  • Cusco Carbon Fiber front strut tower brace
  • Powerslot slotted rotors
  • IE spark plug wires
  • Stoptech SS brake lines(uninstalled)
  • Hawk HPS brake pads
Interior Accessories
  • Autometer Boost Gauge
  • Factory Option 3 Gauge Chrono-pack
  • Heated seats
  • Factory center console swivel cup holder
  • Factory Armrest
  • Floor mats
Exterior Accessories
  • Factory Xenon headlamps
  • Alta 4" Stubby Antenna
  • 20% Tint
  • Custom Black painted hood scoop, grills, bumper
  • Wheel stud conversion with lightweight Muteki lugnuts.
Attached Thumbnails 2006 Cooper S CRONOPACK, Lots of maintenance. Performance upgrades. Must See - PA-1262908_598705150191696_1861106991_o.jpg   2006 Cooper S CRONOPACK, Lots of maintenance. Performance upgrades. Must See - PA-322109_293623510699863_106335822_o.jpg   2006 Cooper S CRONOPACK, Lots of maintenance. Performance upgrades. Must See - PA-387972_258085377587010_176457402_n.jpg
bigramdizzle
08-06-2019 09:19 PM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
08-12-2015 01:24 PM
Drivetrain Products
08-11-2015 11:58 AM
08-07-2015 08:02 AM
Quick Reply: FS:: 2006 Cooper S CRONOPACK, Lots of maintenance. Performance upgrades. Must See - PA
