Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
ST43 pads
Old 11-14-2017, 06:00 AM
MrBlah is offline
ST43 pads
anyone run ST43 pads? I tried the new wilwood BP-40 last weekend but I destroyed a set. I was happy with the bp40 performance except for wear, same with xp12 IMO, also happy with dtc60 except for the terrible rusting dust.
Thinking of giving st43 a try, I'm running 7816 pads
Old 02-14-2018, 05:20 AM
MrBlah is offline
The st43 worked great, .8mm pad wear on the front at a track I've used up a whole set of fronts in a day at.
rotor temp 1000 degrees, no fade
Old 03-01-2018, 07:26 AM
MrBlah is offline
Used same set at VIR this past weekend, full saturday and grand sunday.
Now at 7mm pad left with a little taper so I flipped the pads. I'm pretty happy with these pads, not too much bite for street tires, wear could be better but I'm at the temp limit for these pads, I could go to ST47 but they have a lot more torque so I'm sticking with these for now.
Old 03-01-2018, 07:36 AM
Minibeagle's Avatar
Minibeagle
Minibeagle is offline
What thermal graphic heat paint do you use and where do you get it, mega72?
Old 03-01-2018, 08:37 AM
MrBlah is offline
Genesis paint you can get it on Amazon or race part stores
Minibeagle (03-01-2018)
