R50/53 Jimmyjames budget mini build
Headlights look great. Curious how you got the shroud off of the projector? I got the lens off the headlight no problem (heat gun loosened it right up) but the shroud doesn't seem to want to come off.
Yes I'm on the audizine and 6speed.
I used a long skinny screwdriver and poppedal it off the clips
)I used a long skinny screwdriver and poppedal it off the clips
Just using the top section? Or are you going to add the bottom? Top looks good.
I do and I don't. It looks good with just the top but it kinda looks stock still. I may sport it for a while with just the top then install the bottom when I'm bored with it
Yea, i like it with just the top section.
I like it with just the top as well as the bottom wants to look functional but really isn't...
Seems like you are good with tools, so, may I suggest that you make the bottom part removable? So for things like shows/meet-up or a track day (not sure if it is just cosmetic or functional) you can pop it on and off relatively quickly with a few bolts or something.
Full disclosure - I'm full of terrible ideas like this.
I was thinking about doing that too. Trust me, I'm also full of terrible ideas too. Hahaha. But for some reason I make it work sometime. As for it being for cosmetic or functional? It's only for cosmetics. If I want it to be functional then I will have to make a custom splitter that runs under the engine. I'm actually looking to see where I can pick up a big fat sheet of abs that I can do a custom splitter cutout.
It was an eBay one. It fits great and works better then stock. So far no problems with it. Below is the link from the seller I got it from
http://www.ebay.com/itm/Radiator-Hea...72.m2749.l2649
