R60 Who's running 235/50/17 on a 17x8" +35 offset
Old Feb 17, 2019 | 12:27 PM
ekim's Avatar
ekim
Who's running 235/50/17 tires on a 17x8" +35 offset, Any rubbing without the car loaded? Any with the car loaded?
I'd like to go this way but looks tight/maybe doable?
Thanks,
Mike
Old Feb 18, 2019 | 05:09 AM
iwashmycar's Avatar
iwashmycar
I think you will be just fine.
I am running 17x8 et40 with 235/55/17s no issues at all. Being 5mm more outward (than the images below), I dont think would be any problem. At that point the tire design might make a difference...like if there are big ol rim protectors or not ect.
Old Feb 18, 2019 | 09:57 AM
ekim's Avatar
ekim
Great, thanks for the pics!
Old May 27, 2019 | 06:55 PM
havy's Avatar
havy
Yeah I had rub issues with 235 55 r17 on konig r17x8 et35. I had to go down to 225 50 r17 on et35. I will add I have BC coilovers with cooper crap lift, still lower than stock.
Just additional data to help you decide.
Hope this helps you and others
Old May 28, 2019 | 07:14 AM
ekim's Avatar
ekim
I'm running 235 50 17's with bbs 17-7.5 +35 was good with a slight rub on bad bumps. I need to install a hitch and will carry upto 300lbs of gear at times so I decided to put lift blocks on the back and a 22mm sway bar. No problems now....
Old May 28, 2019 | 05:33 PM
5thscaleracer's Avatar
5thscaleracer
ET35 is too aggressive... especially on a 8" rim.
you should consider 8" with ET40 or ET38 at the very least.
preme123
Jul 12, 2012 10:00 AM
ChiliPepperS
Tires, Wheels, & Brakes
Jan 11, 2008 02:08 PM
jymontoya
16
Oct 1, 2006 10:22 AM
Passat774
Sep 26, 2005 07:18 PM
Pat_Cooper
Mar 15, 2005 03:40 PM
