North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R59 :: Roadster Talk (2012+) (https://www.northamericanmotoring.com/forums/r59-roadster-talk-2012-385/)
-   -   R59 Soft top error message...won't operate (https://www.northamericanmotoring.com/forums/r59-roadster-talk-2012/334589-soft-top-error-message-wont-operate.html)
wesmc Dec 28, 2018 04:56 PM
2013 JCW roadster. She sat through months of cold and rain and when temps were up this week I tried to put the top down and got no effort from the motor and an error message with something like "soft top not operational." It really seems like it just needs a re-set, Anyone have anything like this happen?
Capt_bj Dec 29, 2018 01:06 PM
We've never seen that error message but I'm gonna guess you have the wiz bang nav/sound system with the big display? We don't <dunno where such a msg would display on our's> ... but our top has never malfunctioned either .... and I checked the owner's manual and don't see a mention of this in a quick look (we have a 15s <not jcw>)
1. Let's start easy ... you DID open the latch and 'pop' the top?? You didn't forget the opening procedure did you? (not trying to be cute, in my IT days you'd be amazed how many times the problem was eventually traced to the machine having become unplugged!)
2. "She sat..." are you sure the battery is fully charged? Did you try to open the top with the car running or off? If the car was not running, try that
3. I'd be tempted to try the 'computer reset' procedure of disconnecting the battery for an hour or so .....
please come back once this is resolved .... I'd like to know for the future
wesmc Dec 29, 2018 01:12 PM
Thanks, I was dreading the battery reset thingy but sounds like my best option. I did do all the normal "release the latch and pop it up" stuff. I tried with the engine running and not. Battery is good, she fires right up. I also dug through the owners manual but got no wisdom. I'll get out there tomorrow and try the reset and check back in.
2013_Roadster Jan 2, 2019 05:07 PM
Good luck. I'd be interested in your results as well.
ECSTuning Jan 3, 2019 05:21 AM
+1, bet a low charge battery and put the top down before running the car.
wesmc Jan 7, 2019 06:55 PM
Battery is charged. Trying to lower the top with the car running. Tried "resetting" the windows. Tried disconnecting the battery. Nothing in the area the top folds into. Still says "Soft top cannot be actuated"
Capt_bj Jan 8, 2019 01:33 PM
Sounds like their are few options left other than a dealer?
The top is so unique in these that I doubt a standard 'top shop' could be much help on the lowering mechanism ....
ECSTuning Jan 9, 2019 02:16 PM
Yep the schwaben scan tool will give you a code for it, but then its troubleshooting, it might come down to a hall sensor or something.
Hall Sensor Issues and fix kit: https://www.northamericanmotoring.co...operating.html
Here is the TIS for the R59 if that helps.
https://www.newtis.info/tisv2/a/en/r59-cooper-s-roa/
This is the fault section for the top: https://www.newtis.info/tisv2/a/en/r...roof-soft-top/
Capt_bj Jan 9, 2019 02:48 PM
ECS ... did you LOOK at what those links bring up b4 you posted them
Cuz I looked at 'em previously and saw they were totally useless ....... I dug around 'newtis' for over an hour in hopes of SOMETHING useful .....
MAYBE you have seen something beyond what your links yield but that's not what I find .....
EXAMPLE:AM5402_00100 - Soft top malfunction
Brief description of the test module for non-electrical diagnosis:
Convertible top, malfunction
Applies to:
R59
Content (excerpt):
  • Stiff convertible top
  • Stiff stowage lock
Vehicle communication: No
ISTA path:
Activities / Information search / Function structure / 05 Non-electrical diagnosis - NED / 03 Body / 02 Malfunction / Convertible top malfunction
Important information:
The fault patterns in the test module depend to some extent on the production period, optional equipment, motorisation and other features. It is therefore possible that not all content or different content to that described above may be displayed for different vehicles.
Capt_bj Jan 9, 2019 02:52 PM
and will a car throw codes for things not related to the engine? or for the emissions for that matter
do you get a code for a light out? I don't think so ......
I doubt a top (or sunroof) malfunction would throw a code
but I'm ready to be corrected as I do not own a code scanner.
BUT in addition to sleeping in a Holiday Inn last night I checked a couple of web sites OBD2 code lists and see NOTHING other than engine performance stuff . . . .
(don't OBD2 codes result in 'check engine' light for most cars ...... not a 'top' issue)
ECSTuning Jan 9, 2019 02:57 PM
Yep i saw those, those are the ones I was pointing out since he did not see the links and it might be able to match a code. Otherwise it to the dealership for diagnosis. Just trying to give all the info I could find and know. :)
Capt_bj Jan 11, 2019 02:51 PM
in other words
worthless?
KCinLex Apr 26, 2021 09:14 PM
2015 Roadster top only 1/2" open
If anyone knows what is causing or preventing my soft top from moving I would love to know. When I do the unlock, a gap of abourt 1/2" . No matter how hard I pull or the pressure exerted I simply can't get it to open the 5" inches or more that the manual states will result from the manual opening. The automatic toggle fails to do anything. There is no hydraulic sound when you engage it. There are 2 small purple lights around the lights/toggles over the rear view mirror with a lit up warning that the passenger airbag is off.
I troubleshot this online and have attempted it with the power on and off, with the windows closed and open and nothing makes an iota of difference. Today I took it on a ride to make sure the battery had not worn down which can cause it to not open. Nada, not one bit of difference.
I don't know if I would know the fuse box if it would jump out and bit me, let enough how you to test for a defect and/or how to change one. But if you think that may the cause and can describe how to fix it I will give it a go. Just include a video and photos! Thanks so much for your help.
TG. Apr 30, 2021 04:00 PM
Just to make sure we understand you have an automatic top that won't open right?
And after you release the top lock (turning the manual handle) you are pushing it up with your hand a few inches before using the toggle switch right? It won't open if you don't.
KCinLex May 3, 2021 04:27 PM
I unlock it and there is about a finger width opening. When unlocked no matter how hard I pull on the handle it simply won't budge. I know you are supposed to be back a few inches before engaging automatic, but I can't get it back period. Any help appreciated.
Capt_bj May 4, 2021 01:01 PM
you don't pull back ...
you push UP .... it will lift about 3 inches and stop ... from here the power works ....
{when I push up it sort of 'pops' to the correct position.}
from the owner's manual: If you need one, message me .....
https://cimg2.ibsrv.net/gimg/www.nor...cd1eabed88.png
When you close with power the top will stop at this same point, then you pull down with the handle and turn to latch
[hopefully you haven't hurt anything trying to PULL :no:]
KCinLex May 7, 2021 12:23 PM
Honestly if you were within range I would buy you dinner AND a drink! It worked and I feel a bit like an idiot. I will make excuses for myself in that I had never seen it operate in person and everything I looked at appeared to be pulling it back most likely because I thought that was the direction you were supposed to go. I am truly good at following instructions but if you have the instruction entered into memory incorrectly apparently it becomes more difficult to correct. And then sometimes you may be an idiot as well. (Hey I can admit to making a mistake and hopefully learn from it.) This forum has been a godsend. I have learned so much.
My top is down, the sun is out and I am going for a ride!
Capt_bj May 7, 2021 03:35 PM
glad to be of service ... and remember:
When you are sure everything is right
and the program does not work
something you are sure of
is wrong
old computer programmer proverb
p.s. ya got an owner's manual????
